Old 02-17-2015, 09:50 AM   #31
Campfire Master
Check the rack and gear along each side on the bottom. There may be something jammed in the gear track preventing a full extension.
John
AVid is offline   Reply With Quote
Old 02-17-2015, 04:04 PM   #32
Mine has one hydraulic ram in the center and two slide rails
ford1386 is offline   Reply With Quote
Old 02-17-2015, 05:04 PM   #33
Not sure it's a lippert slide out, it doesn't look exactly like the pictures in the lippert manual onetonford posted. And the hydraulic pump says dewald on it
Old 02-17-2015, 09:18 PM   #34
Did some more research it is a flush floor dewald hydraulic slide out.
Old 02-17-2015, 09:36 PM   #35
onetonford's Avatar
Boy that is different than mine from what I have read on their pdf file it is kept square by two cables. I guess it is possibly a bad cable or pulley. I noticed it also has two rollers at the end of the slide that the slide lowers down into the floor so I would also think could be a bad roller. This is the manual I found for it. http://support.powergearus.com/techd...ideout_Sys.pdf
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is online now   Reply With Quote
Old 02-18-2015, 10:03 PM   #36
I do not see any rollers in the manual what page did you see them
Old 02-18-2015, 10:11 PM   #37
onetonford's Avatar
Sorry I saw them in another manual. Now I can't find it but it was the same brand.
2011 25 RL Wildcat
Old 02-23-2015, 09:12 PM   #38
The slide is straight now, I adjusted the nuts on the hydraulic ram to push out about another inch and it sits level and against the wall now. But how did it get out of adjustment that far it's a steel slide frame with a hydraulic ram?????
Old 02-24-2015, 09:05 AM   #39
arpipeliner's Avatar
Might want to check the tubing you said was flexing. One tube on mine did that and would allow it to jump a tooth or two.
Herk7779 gave me lippert field fix. Push the stud on top of the rail down and grind a slot in a washer to keep it tight. Should be able to find on forum. Was summer of last year. I made over$300 for 2 service calls without getting it fixed. There is a lot of good information here.
arpipeliner is offline   Reply With Quote
cat, roo, slide, wildcat
