Old 02-15-2015, 11:46 AM   #1
Wildcat slide crooked
I have a 2003 wildcat 27rl and noticed the slide seems to lean out at the top when fully extended is this normal for water runoff or something. I tried adjusting the slide but it doesn't affect anything but how tight/loose it closes against the side wall.
ford1386 is offline   Reply With Quote
Old 02-15-2015, 08:27 PM   #2
Bump
Old 02-16-2015, 07:18 AM   #3
Campfire Master
I'm having a hard time visioning what you're describing. I would guess that as long as the slide seals when fully extended and retracted, you're fine. You may want to poke around Lipperts web site. There are manuals for the various slides there. Lippert Slideouts
John
AVid is offline   Reply With Quote
Old 02-16-2015, 07:29 AM   #4
Witch Doctor's Avatar
No that is not normal. There are some adjustments for that. But remember every change you make will change something else. I have the instructions on how to do it if you need to, the video is good but I don't think it shows that.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 02-16-2015, 08:13 AM   #5
When the inside top seal hits the wall it straightens out some but the bottom never comes all the way against the wall
Old 02-16-2015, 08:37 AM   #6
VinceU's Avatar
Looks a bit exagerated and can be adjusted by someone experienced. Also the topper is way too loose. If slide not done right you may have bolts shearing and will greatly complicate things.
Old 02-16-2015, 08:39 AM   #7
Yes I have a new topper I'm just waiting for the weather to warm up.
Old 02-16-2015, 08:43 AM   #8
I did notice when I laid down underneath to try and adjust it the slide rails seem to bend upward in the middle as the slide goes out
Old 02-16-2015, 08:44 AM   #9
caper's Avatar
Is the topper warn or just loose if loose can be adjusted.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-16-2015, 08:51 AM   #10
onetonford's Avatar
Sounds to me like it is not extending fully. Mine when they get to the end of travel they drop into the floor and level off at the bottom top has a slight incline but not to much. Mine are adjustable at cylinder and it shows how in their instructions from lippert.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
cat, roo, slide, wildcat
