Old 03-15-2018, 11:52 AM   #1
acadianbob's Avatar
Wildcat Suspension Surprise
Had our brand new Wildcat to a tire dealer to install steel valve stems for the TPMS sensors. An alert mechanic noticed that one of our shackle bolts was not seated in the frame bracket and that there were just a few threads of the bolt into the lock nut. It would have been quite a surprise to have the suspension come apart out on the highway! Anyway, it's at the RV Dealer now for suspension repair.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 03-15-2018, 12:31 PM   #2
alsdas88's Avatar
Its very good this was caught before serious damage occurred. One thing I always do is a pre-trip inspection. I specifically look at everything that could fail or cause problems on the road. I also do a good inspection when I stop to try to locate things that could have changed since last inspection.
Hopefully your repairs will be easy and you will be on your way quickly.
Alan
2012 Ram 3500 DRW Crew Cab, 6.7 HO Cummins
2014 Columbus M-340RK
'69 Chevy C-10, 396BB
alsdas88 is offline   Reply With Quote
Old 03-15-2018, 06:33 PM   #3
acadianbob's Avatar
Thanks and good advice. Our dealer turned it around in 4 hours. Nice!!
cat, suspension, wildcat
