Old 04-06-2013, 04:14 AM   #1
cpaulsen's Avatar
window
Have an 09 Wildcat 29RLBS. On passenger side next to door...there is a window approx. 13X35. On drivers side rear...there is a wall with no window. Is it possible to install the same size window there like what is on the opposite side?? Anything in the wall to prevent that??
cpaulsen is offline   Reply With Quote
Old 04-06-2013, 05:43 AM   #2
If the 13" dimension is the width, you probably could do that since most campers have studs about 16" apart. If 13" is the height, you would be cutting studs and would have to frame it such that you would be supporting all of the cut studs. Kinda like making a header in a house, if you installed a new window or door in a wall.
If you can, get construction drawings. Remember, measure twice, cut once!
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
