Old 12-08-2012, 05:09 PM   #1
Winterizing
I have a 2007 Wildcat 32 QBBS and I need to winterize it. I dont find any place to suck the antifreeze in to water lines and also I only have one valve on back of water heater for bypass. I really could use some help. Thanks!!
frog32 is offline   Reply With Quote
Old 12-08-2012, 06:59 PM   #2
our old trailer only had 1 valve as well. all it needs to do is connect the cold in and hot out to bypass the heater, it works. remove the anode rod from water heater, leave out till spring. Locate your water pump and look for hose coming into pump from potable tank, is there a Y or valve at that point or one nearby? A short piece of hose with an open end not connected to anything? that is probably meant to be inserted into a jug of anti freeze! Failing to have a permanent winterization valve(s) installed you will need to manually remove the pump inlet hose and install a temp suction hose. hope this helps.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 12-08-2012, 07:18 PM   #3
There is not a hose. Will have to go the other route you suggested. Thank you so much.
Old 12-08-2012, 08:32 PM   #4
buy a bypass kit, worth the money
pwrstroke2012 is offline   Reply With Quote
