Old 10-16-2012, 08:57 AM   #1
MKL
Winterizing Wildcat 25 RL
New at this need help !! Any low point drains on the Wildcat 25RL ? Have looked and can't find any!! Found fresh water tank drain towards rear of trailer. Is it better to simply blow out lines for the winter. Or is a better solution to use antifreeze?? Any help will be appreciated!! Thanks!!!
MKL is offline   Reply With Quote
Old 10-17-2012, 06:12 AM   #2
Oakman's Avatar
I've never owned the same model that you have but on my previous two Wildcats the low point drains were located by the entrance steps between the body and the frame. You almost have to lay on the ground to see them.
I'm not a fan of just blowing out the water lines but many people swear by the method. I always use antifreeze.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
