Old 06-26-2011, 02:26 PM   #1
07 26 bhbs 5th wheel
camping this weekend, the most of the lights started flickering once and awhile, then they stopped working all together. the lights in the bathroom and over the rear bunks still work. the rest stopped. checked the voltage at the bulbs and have 12 volts on both the positive and the negitive side of the bulb. Does anyone have any idea or experience with this. My wife is not happy and is going to be worst if I do not get this fixed for next weekend. thanks
familycamper76 is offline   Reply With Quote
Old 08-05-2011, 07:52 PM   #2
A little late but, you should not have 12 volts on the negative side of the bulb, look for a bad ground. If all the 12 volt circuits are problems check the main grounds, if only a couple circuits you will have to check them.
BCooke is offline   Reply With Quote
5th wheel
