Old 03-05-2016, 03:43 PM   #1
10"x12" hole in floor under shower
Hello Everyone. First post to this forum. We bought a 2016 Wildwood XLite this past September. We were checking the waterlines under shower (through access panel) to make sure they were tight, and discovered a 10"x12" hole cut through the floor of our new camper, presumably to accommodate the ptrap under the shower. You can see daylight through the holes that are already forming in the tarp material under the trailer. Not a lick of insulation in sight. This was obviously done at build, as the linoleum was cut out to the same shape and laying over the hole.
Is this normal? The dealer has it right now for routine warranty check, I brought it to their attention. You could literally stick your head through this thing.
If it is not normal, what do you suggest I request as resolution? I am worried about insects/rodents... along with water splashing from the tires up into the area. I also worry that such a large hole might compromise the floor itself. Hard to tell if they cut through beams or supports.
Any help or advice is very appreciated
Chris from Arkansas
RazorbackFever is offline   Reply With Quote
Old 03-07-2016, 08:40 PM   #2
Phenom's Avatar
Now you've got me curious to look under my Dbud. The shower does sit pretty low, so it makes sense they'd have to cut some floor away to make room for piping. This would also explain the cold temps in the bathroom on cold mornings.
Sean
'16 28DBUD
'16 2500HD Dmax
Phenom is offline   Reply With Quote
Old 03-07-2016, 09:00 PM   #3
My 2010 X-Lite is also cold in the bathroom on cold mornings. I wonder if this is a common issue........
2010 Wildwood XLite 26BHXL
2013 Ram Outdoorsman 5.7l
Ontherock is offline   Reply With Quote
Old 03-07-2016, 09:12 PM   #4
SeaDog's Avatar
When I pull the bottom covering this next week I'm gong to take a look at the shower area, thanks for the info
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 03-08-2016, 08:19 AM   #5
Same issue with my Hemi (sister to Wildwood). Not happy, will probably fill with expanding foam. I can dig out the foam if necessary to get to P trap.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 03-08-2016, 08:43 AM   #6
I have Posted this Many times,it IS "SOP" but in Some/Most cases they also have Removed the area where the Shower Floor Supports are! I had to build a "Bridge" over the Hole to supply a location for the "Shower Floor"! Made a BIG difference in "Spongy Shower Floor" now Rock Solid! It took a few hours to "Engineer and Build the Truss/Bridge over the Hole to Support the Floor but I dont think any Dealer would go to this Effort! Youroo!!
ID:	101344   Click image for larger version
youroo is online now   Reply With Quote
Old 03-08-2016, 08:47 AM   #7
jeff64's Avatar
I had that going on in my Flagstaff too. you could pull the access cover and see a sizable opening between the bottom of the shower and the top of the grey water tank with the traps in between. Don't see any light since the bottom of the TT is covered with the corrugated polyethylene. However, the reason I took off the panel in the first place was, it's a garden shower and there was significant flex in the shower floor around the drain that I wanted to correct, figuring that recurrent flexing of the ABS material wouldn't bode well for the shower pan over the coming years. I had some blocks of thick (easily 2") , relatively hard (you can still squeeze it to some extent) polyurethane foam that after careful measuring and cutting was able to insert between the pan and tank area surrounding the drain. It took care of the issue and can be very easily removed intact if need be
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 03-08-2016, 08:51 AM   #8
jeff64's Avatar
x2 had to bridge around in a couple areas too
14K Equalizer
Old 03-08-2016, 09:06 AM   #9
My EVO was similar. There was a cut out but the tub was braced and a truss already in place, they packed insulation around it. I cannot see any daylight and the insulation filled the void and was level with the cut out. Compared to mine it looks like no one finished the job in yours........
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 03-13-2016, 09:26 PM   #10
Shoot I think I have the same issue in our new 32BDHS. Floor in tub flexes like crazy. I'll have to pull my inspection cover like others and have a look. Anyone get the dealer to repair this? I'm pretty handy but I'm recovering from knee surgery.....
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
show, shower
