Old 06-28-2018, 02:15 PM   #1
12v meter hook up
I have a 23í wildcat and would like to hook up a more accurate system that tells me how much power I have left. There are no 12v outlets, so I assume that iíll Have to go right from the battery. any info would be helpfull
Ctgourd46 is offline   Reply With Quote
Old 06-28-2018, 02:41 PM   #2
PPST Wannabe
kenandterry's Avatar
So......
Iím not sure in your rig, but do you not have a 12v outlet near where the TV antennae booster switch is located? My factory provided booster plate has a 12v socket (for if/when you have a 12v television) the booster on/off button and corresponding green light, and a coax connector.
https://www.google.ca/search?q=rv+tv...WuUagvQPJZzRM:
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 06-28-2018, 02:49 PM   #3
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I personally would connect to the battery posts to avoid inaccurate readings due to voltage drop and if your system comes with temperature monitoring you'll have to connect directly to the battery anyways.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 06-28-2018, 04:32 PM   #4
12v meter
No, idon’t Have any 12volt outlets in this unit. My camper before this had one.
Old 06-28-2018, 04:50 PM   #5
No I did in my previous ca per but not in this one.
Old 06-28-2018, 06:13 PM   #6
This meter will do exactly what you stated you want.
https://www.amazon.com/Victron-Energ...13846592&psc=1
It will monitor voltage, current flow in and out of battery. Can utilize a battery temperature sensor so you will have an accurate prediction of how much power you have left corrected for battery temperature.
It utilizes a shunt that is mounted in the ground lead from the battery, at the battery. Meter receives data from the shunt via a long wire much like a telephone wire. You can read voltage, current flow, percent of charge, and also amount of time left. It adjusts readings using an algorithm that takes into consideration charging inefficiencies so far more accurate than the cheaper units you can pick up off e-bay.
The model in the link also allows you to monitor battery condition and charge via your smartphone. Mine works great from the dash board of my tow vehicle where my phone sits while driving. I can read state of charge and charge current while driving.
I have one and considered the extra $$ to be a good investment.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 06-28-2018, 06:22 PM   #7
Yep...finally got mine installed today. It's awesome. Love the bluetooth connectivity and you can change all the parameters on the smart phone rather than scrolling through all the parameters on the face of the monitor.
Did a test today to see how much charge my new PD Lithium converter puts into my new Battleborn Lithium batteries.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 06-29-2018, 05:17 PM   #8
I purchased my Victron at PKYS.com in Annapolis. Price what better than Amazon and I am tried to making Amazon bigger while it wipes out other retailers.
Less is More is offline   Reply With Quote
Old 06-29-2018, 05:24 PM   #9
https://www.amazon.com/Charger-Adapt...0311000&sr=8-3
Portagie1968 is offline   Reply With Quote
Old 06-29-2018, 06:43 PM   #10
I looked at what Portagie 1968 suggests and after messing with volt-type meters went with the Victron. Voltage meters are heavily influenced by the draw on the battery while you are using a device and it takes a long time for the battery to stabilize. I frequently thought my battery was far more drained than it actually was. I resisted spending the money on a battery meter but after I had it and installed it I wished I had purchased it earlier. We use a single solar panel that I hooked up through the Zamp outlet and 2 6 volt Costco batteries. After hooking up the battery meter I discovered that I had lots of power in my batteries and had needlessly worried about running my batteries down. It takes some work to install the system. I had to run wires to the tongue and batteries. The shunt needs to be dry. I installed it by putting it in a triple outlet box that I sealed with silicone. I could not find a blank cover so I made one out of scrap Plexiglass. I attached the box with the shunt in it on a metal plate that was near the front of my trailer. A little complicated to install. I'm not terribly handy; I have 9 thumbs and a middle finger used for driving but I got it done.
