Old 08-01-2010, 06:27 PM   #1
2010 27bhss TV mount
Hello eveyone,
I'm looking to add a flat screen to my TT. My TT did not come with a tv, or mount, what have you used for a mount? I have been looking at several sites, and I just not sure what would work best for the opening in the wall. Thanks!
SR189 is offline   Reply With Quote
Old 08-01-2010, 06:46 PM   #2
Jan Goldfield
pondlady's Avatar
Sounds a bit strange, but here's what I did. The TV sits in the recessed area. I mounted two relatively small L brackets with foam rubber wrapped around them to hold the TV in place. It works perfectly. I have a bungee cord for traveling. A cheap fix, but hey, it works. You can buy TV mounts from Best Buy for lots of big green dollars if you like.
Jan Goldfield and Donna Morse
Slidell LA
2009 Cherokee Grey Wolf 28BH
2009 Ford 150
pondlady is offline   Reply With Quote
Old 08-01-2010, 07:24 PM   #3
milzat's Avatar
Originally Posted by SR189 View Post
Hello everyone,
Hello SR189,
Welcome to FRF.
I bought an articulating mount from WM and installed it on a perimeter wall(inside wall) in the corner of the bedroom. You should be able to push on the wall to find the stud. I used lag bolts to attach to the wall stud.
milzat is offline   Reply With Quote
Old 08-01-2010, 11:25 PM   #4
Thank you for the welcome!
2010 Wildwood 27BHSS
2010 Chevy 2500 HD, crew cab, 4x4, Duramax
Old 08-06-2010, 12:46 AM   #5
Welcome !
I bought a similar mount from Target - It was an easy job
let us know how you made out with it once you finish
2011 Wildwood 27BHSS
2007 Sub 5.3L 3:73
Hot DW
1 Princess & 2 Busy Boys
Ventura County, CA
Willie is offline   Reply With Quote
Old 08-19-2010, 09:22 AM   #6
calebgold's Avatar
Amazon.com: Peerless PA740 Articulating Wall Mount for 22" to 40"
This is what I use in my living room TV area.
I picked up a smaller less flexable one for the bed room.
11 Mirada 34BH
We travel with two loaded GSD!
San Diego, CA
calebgold is offline   Reply With Quote
Old 08-20-2010, 06:49 PM   #7
I ended up buying a similar mount at walmart. I added a piece of 3/4" plywood to add strengh, and mounted a 32" tv. Works great!
27bhss, tv mount, wildwood
