Old 04-06-2017, 11:01 AM   #1
Question 201bhxl tv
I just purchased a Wildwood 201BHXL 2017. What size of TV have other owners installed in this unit? How did you mount the TV? I believe I want to get a articulating tv mount. I would like to get a 32 inch if possible? I plan to put it above the dinette where they have it setup for a tv. Thoughts? Pictures of what current owners have done?
Best,
Nathan
Nathan17 is offline   Reply With Quote
Old 04-06-2017, 03:09 PM   #2
3boxerss
We have a 28 inch in ours. I believe the wall mount we have lets us tilt the tv up/down and left/right. DH put it by the dinette an fridge like you are thinking of.. Its pouring rain today so I cant get out there and unzip the cover an get in it without gettin soaked.Hopefully it will stop and I will get out there tomorrow and take a pic for you.
2017 FR Wildwood 201 BHXL
2016 Ford F250
Previous 2001 Traillite Bantam B19
3boxerss is offline   Reply With Quote
Old 04-06-2017, 03:50 PM   #3
Thank you so much and that would be great! Do you think a 32 inch would fit?
Old 04-07-2017, 01:35 PM   #4
3boxerss
Well the DH told me I was wrong and our TV is a 24 inch not a 28. There is no way a 32 would fit. Tho he said its pretty solid there where he put the bracket on the wall. A 28 might fit.The problem is the clearance with the cubbard door and the fridge door. The bracket on ours is mounted 3 1/2 " from the top, 4 from the left, 4 1/4 from the right and 8 1/2 from the bottom. These measurements are from the inside of the square on the wall an dont include the trim pieces. When I tilt the TV as far as it will go I have 2 1/2" clearance from the fridge door and 1/2" from the cubbard door.
ID:	134068   Click image for larger version
ID:	134069   Click image for larger version
ID:	134070   Click image for larger version
ID:	134071   Click image for larger version
2016 Ford F250
Old 04-07-2017, 01:59 PM   #5
This is so helpful, thank you so much. I am glad you showed and stated where the bracket is mounted in case I do try for a 28 inch TV. The 24 inch looks really good in your camper. Super helpful!!
