Old 06-26-2017, 02:00 PM   #1
241qbxl air Conditioner
I am new to RVs, is the ceiling mounted air conditioner like a window air conditioner in your home? The fan always runs and the compressor goes on and off? My unit never shuts off is this normal?
tomahawk246 is offline   Reply With Quote
Old 06-26-2017, 03:49 PM   #2
gpaw56's Avatar
Is your a/c switch on the unit itself? If it is I'm not real sure how it operates. If you have a thermostat on the wall there should be an auto, high and low setting. The auto setting should shut the fan motor and compressor off when the temperature setting is met. The fan motor will run continuously on high or low and the compressor will cycle on and off.
gpaw56 is offline   Reply With Quote
Old 06-28-2017, 05:41 AM   #3
There is not a thermostat on the wall, fan always runs. I am wondering if there is a setting that I am missing?
Old 06-28-2017, 12:23 PM   #4
Only the compressor cycles on and off
Adam79 is offline   Reply With Quote
Old 07-06-2017, 03:24 PM   #5
Just like a window unit the fan runs constantly the compressor cycles as needed,
and dang if it ain't loud
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
railroaderone is offline   Reply With Quote
Old 07-06-2017, 03:29 PM   #6
The good thing is that it cools off the camper very quickly.
Old 07-09-2017, 11:48 PM   #7
Huh. We have a 241qbxl (2017), and it has a thermostat. Mounted above the couch opposite the door. Do you have ducted vents available?
Sundancer is offline   Reply With Quote
Old 07-10-2017, 07:21 AM   #8
No ducted vents for air, thermostat above couch is for heat only.
air conditioner
