Old 08-03-2015, 04:04 AM   #1
312QBUD entertainment center
Is it possible that I can add a TV bracket to the entertainment center without the screws going into the outdoor kitchen? My lacrosse had this setup and I like it because it secures the TV. Thank you
Koolcamper is offline   Reply With Quote
Old 09-07-2015, 11:29 PM   #2
I go RV'ing not Camping
jgourlie's Avatar
I think it would be possible if you glued some wood to the entertainment centre inside the trailer and then used screws that went through the wood into the outside kitchen wall but not through it....should be strong enough with some pl 2000 glue or something similar. If you were to just put a short screw for the tv mount into the wall, i think it would come out.
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 09-10-2015, 06:25 PM   #3
I use the Same bracket that is used in the front living room and found some sort of wood using a stud finder and mounted mine. It is a little off center which does not please the wife. But travel and leave the tv mounted onto wall and never had a issue. Click image for larger version
Name:	ImageUploadedByForest River Forums1441927533.583844.jpg
ID:	88328. Got bracket from
Amazon
hillyer05 is offline   Reply With Quote
