Old 05-22-2017, 01:49 PM   #1
31BKS wifi thermostat options
I've done some searching previously and didn't see a clear answer but are there any new best Nest type thermostats that can be installed in my travel trailer without doing any sort of additional wiring changes ?
gouda272 is offline   Reply With Quote
Old 05-23-2017, 11:04 AM   #2
Most home furnace/AC thermostats (including the nest, I checked) run on 24 V power. I think the RV thermostat is also 24V but you should confirm this.
You might lose some functionality such as the high/low fan speed...
Hunter 42999B Digital RV Thermostat - Upgrading the OEM Thermostat
read that install writeup to get a better idea.
mkosu04 is offline   Reply With Quote
thermostat
