Originally Posted by DFW Rusty
I have an x-lite with (I'm pretty sure) is the same exact antenna and they are junk. Non adjustable, and have the "boost" that doesn't really seem to help. I'm lucky if when we go camping if I get 1 channel.
Ours isn't bad, but our prior Winegard Sensar was better by a lot. However, some of your reception problem could be the coax cable. Our new TT was one where the connections at the booster plate were backwards, and during troubleshooting I found that there was excessive loss in the cable from the Continu.us unit - you can get to the coax at the antenna by just removing the bolt and lifting up. I found that during install the cable was pinched by a tight kink. Fortunately, there was just enough slack where I could cut the pinch out and put on a new connector and get the antenna back on with the help of DW's piano-playing fingers versus my meat hooks.
