Old 12-14-2013, 11:21 PM   #1
32' wildwood dometic a/c drain
hello, I have a 2008 32' wildwood van with a dometic roof top a/c. I was wondering if anyone knows where the a/c drain point is and where is it spose to drain on the van?
thanks.
JohnW is offline   Reply With Quote
Old 12-15-2013, 11:31 AM   #2
rracer5's Avatar
thanks.
What sort of problem are you having? Water dripping inside? The unit itself should just drain onto the roof. On really humid days, I have had some condensation form on the inside roof grate and drop a few drops but, that's about it.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 12-15-2013, 11:28 PM   #3
hi, thanks I thought it would just run on the roof. we've got some hot days down here in oz at the moment so have had the a/c on. had water dripping down through the center join on the annexe lip/gutter running down the side of the van over the cover behind the fridge. but when I 1st got up on the roof for a look I couldn't see it running on the roof to the gutter. maybe it evaporated by the time I got up there...
got up there again this morning and could see it running on the roof to the gutter.
looks like i'll just have to re-do the center join in the gutter so it doesn't leak through there.
thanks for your reply.
dometic, drain, wildwood
