Old 08-22-2014, 02:14 PM   #1
Angelbunnie13182's Avatar
356qbq black tank question
Has anyone else had trouble getting their black tank to completely empty? It gets full and we pull the handle to dump. But after about 10 min it's only gone down to 1/3 full. The manual for the RV said to not let it get completely empty but I wanted to get others opinions. Thanks. By the way the attached picture is the setup we have for the back black tank hose to have it level so it will all push forward to the front Y attachment and dump.Click image for larger version
Name:	ImageUploadedByForest River Forums1408734752.502875.jpg
2015 Forest River Heritage Glen Lite 356qbq
"The Pod" aka Place of Duty
Christina LaPlaca
2015 Forest River Wildwood Heritage Glen Lite 356qbq
"The Pod" Aka "Place of Duty"
Visit my blog:http://www.rvlifemilitarystyle.blogspot.com
🌺 Christina LaPlaca 🌺
Angelbunnie13182 is offline   Reply With Quote
Old 08-22-2014, 03:00 PM   #2
Oklahoma Proud
MillerTime's Avatar
U may have to use the black tank flush to clean it really well to were it will show E.
I drain mine completely and flush till as clear as possible. And check level. Sometimes it wont show e but most times it will. I then add some pinesol and water (probably3-4 gallons) and then a tablet at this point it usually shows 1/3 .
I never leave the tank dry (except winter) but I won't leave any black water in it from before. When I dump tanks, I flush tanks, period.
U may have a vent issue or valve issue if it takes that long to dump your tank though.
Good luck!!
Old 08-22-2014, 07:45 PM   #3
vinmaker's Avatar
That is quite the set up you have there for your sewer. How many feet of sewer pipe you have set up? Does it take a while to set up the system with the Y and everything?
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-23-2014, 10:47 AM   #4
Oklahoma Proud
MillerTime's Avatar
Here's the setup we are using now. Its on a somewhat seasonal site, and the joints aren't glued together, but no leaks. If we leave we will just pull to the side slightly and undo our flexible hose ends with bayonet ends
ID:	61262   Click image for larger version
Old 08-23-2014, 12:27 PM   #5
Actually it was pretty easy. We have the rhino flex hoses. The one that is at the first black tank is 10ft. The second that connects to the back black tank is 15ft. Outer neighbor helped us rig up this system but the hose is sagging in the middle. We just have rope on either end holding up the board. Today we are going to go get some cinder blocks to use to keep the plank the hose is on level. Took about 45 min to get it all sorted out and set up.
Old 08-23-2014, 12:31 PM   #6
Good luck!!
Ok so sounds like I might not be putting enough of the water and sewage solution mix in to my tanks. I have only been putting 1gallon of solution that I have to mix with water into each of my black tanks after I flush them. Should I use more?
Old 08-23-2014, 03:12 PM   #7
Infractee
Yes, 1 gallon will just end up at the drain/gate valve. Will not be enough to work on the "material" inside the tank itself. I always start a trip with 5 gallons of water in black tank plus the enzyme additive.
RhoZeta is offline   Reply With Quote
Old 08-23-2014, 03:29 PM   #8
So we are parked in one spot, does that matter? So 5 gallons of the enzyme/water mixture after each time I dump my tank? Which is about 1x a week.
Old 08-23-2014, 04:14 PM   #9
Ford Idaho's Avatar
Correct, you need a good starter mix.
Old 08-23-2014, 04:31 PM   #10
Infractee
Yes even if you are seasonal you need lot of water or "materials" will not break down and will turn into concrete...
black, black tank, tank
