Old 08-18-2013, 08:24 PM   #11
Got our 356qbq Friday and spent the weekend at fort Meyers beach.96 degrees and one a c would not have been enough. Still got a little warm in main unit. Didn't have a fan to blow the second ac into the main room but it was down right chilly in the bed room. So as sun went down we shut off the second ac and it handled everything and shut off on a regular basis.only got 12-13 mpg going home .i was hoping for better. Could not find any major problems with unit just the p trap leaked from compression ring not being seated correctly. We had the fantastic fans installed in the two bathrooms can't wait to use them.....
Ecclesiastes is offline   Reply With Quote
Old 08-21-2013, 08:00 AM   #12
Chewie's Avatar
12-13 mpg is pretty good considering how big the HG is.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 08-21-2013, 08:34 AM   #13
Vtxguypei's Avatar
356qbq
The mileage really surprised me for sure but I don't drive or own a truck of that size so I feared much worse. Just a note on the backroom experiences we have had. The lower bunk dropped on the kitchen end after 3-4 youngsters sat or bounced a bit on it two connectors screws sheared off. I did a quick fix the day it happened with a cleat along the length of the wall but it has torn the screws away as well without many bodies on it..only one using it. The fix I hope will be to try get fastened to the wall again hitting a framing member with something more solid than the #8 sized screws that were there originally....and I have placed some 7 1/4 inch blocks under each end of the bed and the center to add some support in the meantime. Will try and find out from FR exactly where the framing members are located in the bunkroom pop out but that might be a challenge to as I can't seem to find a contact us number or email question window on their site. If anyone has experience with this please advise. The only other things we have done are installed drawer guides for the two under seat storage drawers which really didn't take much time at all or that much work either.
Vtxguypei is offline   Reply With Quote
Old 08-21-2013, 08:49 AM   #14
Chewie's Avatar
Forest river main # 574-296-7700. They can transfer you to the wildwood branch. I called them the other day for some info in stain colors and they were helpful.
Old 09-23-2013, 08:35 PM   #15
I am looking at purchasing this same camper. What tow vehicle are you using?
Jakewb5025 is offline   Reply With Quote
Old 09-23-2013, 09:22 PM   #16
Chewie's Avatar
I use a '12 ram 3500 dually, cummins diesel
