Old 10-25-2017, 03:01 PM   #1
3rd Coaxial Input on Outside of Wildwood 27REIS
Question about our 2017 Wildwood 27REIS. There are 3 coaxial inputs on the outside. Two of them are listed Sat/Cable and are in the back corner by the fresh water tank but the 3rd is away from them over on the slide-out with no label. I ask the dealer where we purchased the camper and they did not know what it was for either. I cannot find any mention of it online and I haven't been to a campground with cable yet to test so any help is much appreciated.
Thanks,
Mike
swdrafter is offline   Reply With Quote
Old 10-25-2017, 03:15 PM   #2
The 3rd located by itself is most likely a hookup for an outside TV , look around and see if there is a bracket to hang a TV.
Retired Navy
Indiana
Hemisphere Lite 327RE
Silverado 2500HD 4x4 6.0 gas
Sailor Bill is offline   Reply With Quote
Old 10-25-2017, 03:19 PM   #3
Yep... often times the 3rd or (4th) port on the outside is for connecting an outside TV.
The port is an output (usually split off from the inside connections) and not an input.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 10-25-2017, 05:13 PM   #4
I will try to hook up a tv. I know there aren't any brackets outside and with the connector being on the back of the camper I didn't even think of it being for an outside tv. Going camping this weekend will let you know. Thanks for the input.
Mike
Old 10-26-2017, 05:23 PM   #5
jovett
Mike
I added one of these to my TT for the satellite connection because the one on most units will not permit power to go back to the dish I have outside unless you unhook the U shaped jumper inside. I marked mine sat. in. If you have a Sat. system and you can't get it to work I would try hooking up the coax from you're outside dish. If everything is hooked up right inside it should work after you change the input setting inside. Jovett
jovett is offline   Reply With Quote
wildwood
