Old 08-29-2015, 08:08 AM   #11
Mcindia's Avatar
Originally Posted by gljurczyk View Post
I have a question for ya? How many hose outlets are there sounds like (2) but could be (1) which would be nice. I have 2 gray tanks and 1 black. What the pita is that I have also 2 hose outlets. Either I have to wye them together or keep moving the sewer line. When hooked to a sewer if I'm staying awhile I like to leave both grays open....Is yours the same? I don't know why they couldn't put them all together in one outlet. I refuse to put a 90 degree elbow in to tie them together. I have seen that done. But we all know what happens with 90's.....
I think one outlet is for black tank and one for grey, have to figure what valve goes to each outlet.
Mcindia is offline   Reply With Quote
Old 08-29-2015, 09:04 AM   #12
My 15 312QBUD is a different setup vs my 16 312QBUD....on the 15 I had the long main valve and in the frame rail it had a black then a grey...on my 16 I have the same main valve but the smaller valve was moved farther toward the axle and the grey tank has a pipe coming down with a valve just before the main valve opening..I couldn't figure out what was what..so I just started filling tanks one at a time then opening valves and seeing when I got flow and from were lol
Koolcamper is offline   Reply With Quote
Old 08-29-2015, 09:27 AM   #13
I have 2 outlets on my Flagstaff like Glenn's Rockwood. I hard plumbed the rear tank into the front discharge, added a slide valve and just keep the rear tank valve open and just keep the added valve closed until I want to dump. I NEVER leave any tank open as I don't want to vent the entire campground septic/sewer system thru my camper.
Old 08-29-2015, 11:23 AM   #14
I've never had any problems with mine venting when I leave it during the week..but that's not to say that it will lol
Old 08-29-2015, 11:27 AM   #15
You may not, but you are essentially venting the cg system with your rv venting system. Think about it.
Old 08-29-2015, 02:39 PM   #16
Pump handle
Glad you figured it out
Good you figured it out I wish mine had been that simple I have a 2016 Prime Time 334 CKT they plumbed the third valve inside the belly cover where it could not be seen and it was closed. Once the tank filled up it let go had water pouring out under the trailer. I am still waiting on Prime Time to ship the new tank to the dealer for replacement it has been a month now.
jm812 is offline   Reply With Quote
Old 08-30-2015, 08:29 AM   #17
I have the same issue with my 2015 2608. It's nice to have the extra gray capacity but the set up and dumping and be a PITA as mentioned. So for one or 2 day stops I've come up with an easy solution. The 2nd gray is for the kitchen only so I save all dish water in a plastic pan and when about 1/2 full I pour it into the toilet eliminating the need to hook up or dump it this gray. I've found a few trips to the toilet is worth the hassle. Now when I'm in a location for a while I set up the 2 sewer hose setup using a Y connector. This works well for me.
robbdrell is offline   Reply With Quote
Old 08-30-2015, 08:48 AM   #18
Do you disconnect the drain on the kitchen sink and drain in a bucket?
Old 08-30-2015, 09:06 AM   #19
Nope. Just try to catch all dishwater before it goes down the drain. I don't get it all but it so little I don't worry about the gallon or so that gets in. Sometimes I'll dump it somewhere but most of the time wait until I hook up both tanks.
Old 08-30-2015, 09:30 AM   #20
I'll continue with ours that is hard plumbed into the front discharge. No hassle and easy to empty.
tank
