Old 05-24-2019, 02:38 PM   #1
A/C in the South
Any luck with portable air conditioners? Itís mid 90s here with high humidity. Iím baking in the sun! 30 amp tt with one a/c. I shouldíve gone for 2, but live and learn. Air runs nonstop to keep it at 85. Only one dinky bathroom fan. Iím considering a hotel for the next week! We seemed to have skipped spring and gone straight to summer. Iím full-time stationary for now.
Thanks again. You guys are a big help!
xr751 is offline   Reply With Quote
Old 05-24-2019, 04:06 PM   #2
kfd82's Avatar
Id suggest not running that bathroom fan, its pulling your A/C air up and out into the atmosphere. That cant be helpful...
Try some circulating fans and try closing vents and doors in unused rooms. (like close off the bunkhouse if its not being used) I know this may not apply to you.
kfd82 is offline   Reply With Quote
Old 05-24-2019, 04:20 PM   #3
pull your shades to stop solar heat gain from windows. leave the door shut, don't run in and out. What size is your ac? maybe able to get a large unit but still a costly upgrade.
Open the air damn and let the air dump out so you are not losing precious cold air in the vent lines. (depending where a/c unit is located and were you are at)
Kimber45 is online now   Reply With Quote
Old 05-24-2019, 04:21 PM   #4
There are people who use them. You have to figure out how to get the cooling air and the heat they remove outside the TT. See the hose in the pic below:
You'll also have to run the power cord outside, either through a window or a slide seal, and plug it into the 120VAC outlet on the pedestal. Your 30 amp supply isn't enough to run your rooftop AC as well as the portable AC.
2011 Traverse LT, 3.6L, FWD
Old 05-24-2019, 04:38 PM   #5
Cover your windows with towels. If you don’t have shades.
Orient the coach with the nose facing the west if possible or have the awning side to the west. Deploy your awning to help keep the sun off the side of the coach.
Park around trees etc.
Clean the filter on the AC unit if you haven’t already.
Have you checked to see if your return and supply are are not short circuiting?
Set the AC fan on your TStat to high vs Auto if you haven’t already.
Let the AC run all night and have a head start for the day.
2016 F350 PSD SRW 4x4
2019 325 Wolfpack 13
Vikes79 is offline   Reply With Quote
Old 05-24-2019, 04:42 PM   #6
Some things you might want to try before you plunk down big bucks for a portable AC:
1, You might want to "pimp your AC:"
Pimp My Coleman Mach 3 AC
2. If you have ducted AC, a number of people have reported that the cold air has leaked out of the duct past the last ceiling register. They pulled out the register and sealed the duct downstream of the register and got a lot more air into the TT.
Old 05-24-2019, 04:56 PM   #7
Iwannacamp's Avatar
If I read correctly...your unit is less than 30 ft? If you have a 15K unit..and it works.. and y'all ain't standing there with the door open... and it isn't 115 out side and you have any shade. There really any reason your a/c cannot work. We had a 35+ OAL 5er and it worked...perfect? No, but it did pretty good. If we arrived at 6P in 90+ weather a 60% humidity it would take till bed time to cool off, but then it kept up pretty good after that.
Do you have a thermometer? Take a return air temp and a supply air temp(leave you infrared in the box) and look for a 20 deg difference. It cannot be 95 or 65 in there as the readings are out of the efficiency range of the a/c. Temp OK? It is working. Temp 15 or 26 deg. we have stuff to check. Let us know.
2017 Puma 297RLSS
Iwannacamp is online now   Reply With Quote
Old 05-24-2019, 04:56 PM   #8
Iwannacamp's Avatar
X2 on all of this
2017 Puma 297RLSS
Old 05-24-2019, 05:12 PM   #9
jeff64's Avatar
Pumping the ac works. Block off all the roof vents with either the camco vent pillows or find an appropriate foam material and cut to fit. Put a circulating style fan on the floor aimed towards ceilings in each room. Dehumidifiers also help pull humidity and make ac more efficient
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-25-2019, 12:45 PM   #10
You can add another AC unit even if you have a 30 amp. trailer and it is not wired for an additional AC. I made the same mistake you did, I purchased a Crusader Lite, 30 amp with one AC and not wired for a second AC. I added a second 15K unit to our bedroom where the skylight & vent was located. New unit fits the opening perfectly, I wired the unit through a added 20 amp circuit breaker mounted in the lower forward cargo area, added a another 30 amp twist lock plug on side of skirting and purchased another power cord. The added AC unit has the ceiling controls.
Walholler is offline   Reply With Quote
