Old 06-03-2018, 05:23 PM   #1
AC not blowing hard out of all vents
I have a 2015 Wildwood 241QBXL. The AC blows ice cold but it only blows hard out of the vent facing the rear of the trailer which is the bathroom area. The 2 vents on the side blow some and the vent facing towards the bed area doesn't even seem to be a vent at all as it is on the side where the filter is and has zero air coming from it. It also has 2 vents that blow straight down towards the floor and they don't even have much air coming from them. Am i missing something here?!
Thanks!
GeramieI is offline   Reply With Quote
Old 06-03-2018, 06:09 PM   #2
Head Rambler
That's not uncommon. There are several threads here about people having the same problem, myself included.
1. Start by removing the return (ceiling) grill and looking at the partition between the supply and return to make sure that it's sealed.
2. While you have the grill off, look at where the ducts connect to the plenum A/C discharge and make sure that sealed up but open to the ducting.
3. Take your phone or other camera that will take a picture looking into the ducts, and take a picture or two down the ducts and see if they're crushed or blocked by something.
4. Remove some of the registers and check them to see that they're sealed to the ducts and take some pictures looking both ways down the ducts. On the end register, take a picture toward the terminal end of the duct to make sure that it's sealed and not leaking air out into the ceiling.
Once you've done these things and rectified anything that needs it, you can order some adjustable registers for the places that you need to direct or reduce the flow out the register.
Gotta go campin!
Old 06-03-2018, 06:33 PM   #3
Thanks for the reply. My unit doesnít have ceiling vents, only vents on the actual ac unit itself.
Old 06-03-2018, 06:42 PM   #4
Homebrew's Avatar
Slide the little white tab between the two round knobs.
This will transfer the air to the upper vents
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 06-03-2018, 06:51 PM   #5
Iíve done that and it still doesnít blow out of the vent that is towards the front(bedroom area).
Old 06-03-2018, 07:18 PM   #6
I spent a good hour picking chunks of foam out of my A/C ducts after the first use. Most were small but they'd get caught on the deflectors at the outlet and in turn catch the rest coming down the line.
Another idea that doesn't work as well in practice as it does on paper (forming the ducts into the insulation foam). I wonder how much cool air is being wasted just refrigerating the roof?
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 06-03-2018, 07:48 PM   #7
Check your A.C. duct work
2017 Coachmen Catalina 283RKS
2004 Chevy Silverado 2500HD Crew Cab
Crabman is offline   Reply With Quote
Old 06-03-2018, 07:58 PM   #8
Who Dares, Wins
doc73's Avatar
Not knowing much about HVAC but is the clear deflector on backwards? Isn't the return the area it is blasting that fine cold air right back towards?
Our Greywolf had some pretty crappy flow one direction on the non-ducted system.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 06-03-2018, 09:01 PM   #9
I put that deflector on myself to try and deflect the air coming from the vents that are blowing toward the floor to the front/bed area. However, they don’t blow hard enough and it didn’t make a difference. But yes, it is directing air past the return/filter
Old 06-03-2018, 09:19 PM   #10
Retired JSO's Avatar
Our second unit does the same thing. I close or almost close the rear tab to even discharge.
Retired JSO is online now   Reply With Quote
vent
