Old 10-10-2017, 04:35 PM   #1
Send a message via Skype™ to bdoppel
Air pressure monitors
Does anyone use these? I am curious as to their accuracy.
Thanks!
bdoppel is offline   Reply With Quote
Old 10-10-2017, 04:36 PM   #2
I should have titled this "Tire pressure monitors". Sorry.
Old 10-10-2017, 05:04 PM   #3
Tigger1's Avatar
After reading about tire blow-outs, we decided to buy a TPMS. We purchased the EEZTire 4-sensor system. Used it for the first time this past weekend and it worked as advertised. It gave us peace of mind looking over at the monitor which cycles from tire to tire every 5-6 seconds. It has a visual and audible alarm that goes off if tire pressure goes higher or lower than what we set. It also monitors tire temperature. The sensors take a CR1632 battery for when they need changing. The monitor has a rechargeable battery.
2018 Rockwood Mini Lite 2104S
2003 Toyota Sequoia SR5
2014 Jayco JayFeather x17z Hybrid (2014 - 2017)
Tigger1 is offline   Reply With Quote
Old 10-10-2017, 05:30 PM   #4
Gumpster808's Avatar
We bought the TST system this year and love it. Got the non flow thru sensors since they are lighter and easier to change batteries.
Mike Benson from TST frequents this forum and I know 4th of July weekend someone posted a problem with theirs. Mike responded with his cell number so they could call him and work through the issue. Also Chip from Great RV products is on here as well - they rep the TST systems.
Depending on overall length may need the repeater to ensure all sensor signals get to the monitor. Think that is the same with most systems though.
If you look at the TST see if it is the new color monitor they came out with. Can switch between trailers etc easily and much easier to see than the monochrome one.
Their customer service is top notch which is all too rare these days.
Just my thoughts.
Lynn & Dennis
Nights Camped 2017 - 35 / 2018 - 15
2014 3051S - First RV for us
2018 Hyundai Elantra Sport Toad
2015 Harley CVO (retirement bike )
2015 Challenger ( Wife's Toy)
Gumpster808 is offline   Reply With Quote
Old 10-12-2017, 06:41 AM   #5
Camper
I have an older set that I am looking to replace next year and they work well.
Just know that you should have metal valve stems installed if you are going to use the screw on type of sensors that are most popular.
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
Macrosill is offline   Reply With Quote
Old 10-13-2017, 09:22 PM   #6
Truck System Technologies Rep
TST TPMS
Thank you all for the feedback!! Yes our New Widescreen Color Monitor will work with ALL existing 507 and 507 Flow Through Sensors.
If anyone has any questions with their TST TPMS. I am always available at 210-420-0132
Thanks,
Mike Benson
TST TPMS
mbenson1234 is offline   Reply With Quote
Old 10-13-2017, 10:03 PM   #7
gectisme's Avatar
I have been doing a bit of research on TPMS's recently because the new color screen TST is offering, trying to decide if I should upgrade. Anyway, the system you have, EEZTire is the only TPMS that I have found so far that supposedly solves the issue of an intermittent signal or lost signal. Have you driven away from your TT and ever noticed how long it takes for the Monitor to let you know there is no signal? I read a blog that it was very quick with the EEZTire TPMS. I actually read a manual for the TireTraker TT-500 and it stated 3hrs before it gave a warning that the signal was lost. The TST takes somewhere between 1/2 to 1 hour.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper).
MISSION COMPLETED!
gectisme is online now   Reply With Quote
Old 10-13-2017, 10:21 PM   #8
There are tons of threads on TPMS systems. Just put TPMS into the search field at the top of the page.
Here's one that's active right now:
TPMS recommendations
2011 Traverse LT, 3.6L, FWD
Old 10-13-2017, 10:37 PM   #9
rsdata's Avatar
the question should be not one of accuracy but do they alert me that I have a problem with low pressure or high temperature with a wheel/tire?
The answer to that question is yes. And they provide you some amount of safety to pull over after you see or hear the low pressure alert and possibly save you hundreds or thousands of dollars of damage to your trailer that happens when the damaged tire flays away at the under-carriage of the trailer as you continue to drive down the road without the knowledge that you have a flat.
I have the TST 507 RV kit now for 2 years with flo-thru sensors. Chip at Great RV Products has a good price and great service. Rare you can actually talk to a real person when you have a question these days.
I wrote a post to help those that need to change the battery here...
TPMS 507RV battery change hint
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 10-13-2017, 10:58 PM   #10
There's a TST rep posting, including his phone number, in the thread I linked to in Post #8 above.
pressure
