Old 09-10-2016, 06:10 AM   #21
contourcrazy's Avatar
Send a message via Yahoo to contourcrazy
I replaced the ST205/75/R14 RidgeWay Pro Load Range C with 205/75/R14 Goodride Trailer ST Load Range C. Our tires were the factory tires and we have our TT since October 2015.
2016 Wildwood 261 BHXL
2012 Ford F150 XL 5.0 L
contourcrazy is offline   Reply With Quote
Old 09-10-2016, 01:52 PM   #22
Commercial Member
So no increase in load capacity. Are you expecting some better performance? If so why?
I write a blog on RV tire application and safety and give seminars on tires at RV events across the US. 40 years experience as tire design & quality engineer for major tire mfg. Freelander 23QB on Chevy chassis is my RV
RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 09-11-2016, 04:22 PM   #23
I am not expecting better performance. I had to replace one tire because of separation problems.
2012 Ford F-150 XL 5.0L
Old 09-11-2016, 04:22 PM   #24
Name:	ImageUploadedByForest River Forums1473628955.712941.jpg
Old 09-11-2016, 11:40 PM   #25
Commercial Member
Attachment 119947
You were lucky to catch it before it came apart and did damage. Tire should be covered by warranty if from a regular tire company. You should also file complaint with NHTSA. You will need DOT serial for that.
From wear pattern it looks like you are running low on inflation by maybe 10 psi for the load you have. What is your scale weight?
RV Tire Safety Blog
Old 09-12-2016, 01:01 PM   #26
I haven't weighed it yet. I agree I was lucky. Those tires were the ones from the factory. we are dealing with Tire Shield to try and get reimbursed for that tire. Now you understand why I had to replace the tires. All tires looked similar wear. I will have to get to some scales and weigh in. I will also watch my inflation.
Old 09-12-2016, 05:55 PM   #27
Commercial Member
For inflation I suggest the inflation molded on the tire sidewalls. LR-C is probably 50 psi.
This is also probably the inflation on the tire Placard on driver side of RV toward the front.
RE weight You can use standard CAT truck scale and assume a nominal side to side unbalance of 6% so figure each axle weight is split 47/53%. The 53% number should be no greater than 85% of the tire max load as molded on tire.
If you can't get individual axle loads I suggest you also estimate a 47/53 axle to axle split to be conservative
So total of 2 axles is 10,000 One axle may have 5300# and one side may have 53% of 5,200# or 2,809#. This would mean the tires better be rated for at least 3,305# or you need to put RV on diet.
With the numbers you then know how important it is to learn actual individual tire loading.
I have a number of posts on my blog on weight and inflation. Just be sure to follow the advice for trailers not for Motorhomes which is different.
Don't forget about the NHTSA complaints. That is the only way we can ever push RV companies to select better tires.
RV Tire Safety Blog
Old 09-13-2016, 09:07 AM   #28
What is your recommendation for my truck. I have 235/75/17 Hanlook's. I have been looking at Michelin Defender LTX. Any opinions?
Old 09-13-2016, 10:44 AM   #29
Commercial Member
I try and stay away from specific brand suggestions other than select a brand with lots of dealers and outlets nationwide and a brand that puts the tire company name on the tire sidewall.
Best bet for tow vehicle is to confirm the load when hooked up and fully loaded and not exceed any vehicle rating. You have a size, Load Range and pressure recommendation of driver door jam.
RV Tire Safety Blog
Old 09-13-2016, 11:00 AM   #30
Fair enough. I will check into it and I will let you know what I decided to do.
tire
