Old 09-08-2016, 09:43 AM   #11
Originally Posted by Mrs Evans View Post
Nice idea! Never thought of that and here I was holding back because of the thought of having to take them down every time we move - now I might just put up some pictures - woot woot!
We have several "Special Things" friends have given us through RVing that are "On the walls" without the Putty they would have to be "Removed Every Time"! Youroo!!
Old 09-08-2016, 04:48 PM   #12
Command strips and for heavier items, I use command velcro strips.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 09-08-2016, 05:04 PM   #13
We use Velcro command strips for everything we hang picture wise. So far.......100% success over the past 5 years. We also have a long vertical mirror that we hung but did that with Gorilla tape.
Filterman is online now   Reply With Quote
Old 09-08-2016, 07:26 PM   #14
We use Command strips for all lightweight things. For heavier things, one or more Command hooks (with a piece of picture wire attached to a frame, if needed) always do the job. I have a metal magazine rack hanging on 3 5# Command hooks and it hasn't fallen off yet, even when full of magazines. I can't remember how we ever camped before Command hooks were invented
ellen and ken, 3 dogs and Adventure Cat
2012 Mini Lite 2109S
2005 Sierra 2500HD Duramax/Allison
ekrus is offline   Reply With Quote
Old 09-08-2016, 07:54 PM   #15
thanks to all of you for your replies and for some new ideas. I went a bought some Command Strips today. Ready for the maiden voyage of the new TT.
Sawtooth is offline   Reply With Quote
Old 09-08-2016, 09:43 PM   #16
kittlecat's Avatar
Command strips are wonderful! Be sure you use the correct number of strips depending on the item you want to hang and be sure you use the correct size (weight the strip can hold). Everything on the walls in my TT are hung with Command strips and/or museum putty. Neither leaves marks on the walls and both can be easily removed, regardless of the temperature. I learned this when we had to strip my TT bare in February in Michigan as the insurance company totaled it. All the Command strips came off clean, not that it mattered as the TT was going to salvage, but I was still impressed. Thus far, I have only had 1 item come off the wall and that was because I did not use enough Command strips when I initially huge it. I even have a large piece of stained glass hung on the wall and it stays put. Happy hanging! I've made my TT my home on wheels, including wall decorations and pics of people and places I love!
Kittlecat
"Integrity simply means not violating one's own identity." Erich Fromm
"You have to understand who you are to know who you are not." Anonymous
"Know yourself, know your world. Change it." Anonymous
kittlecat is offline   Reply With Quote
Old 09-09-2016, 07:22 AM   #17
our wall covering has some texture to it and the command strips dont seem to hold in the heat. on the smooth surfaces like cabinets the command strip hold well, we even tried alcohol wipes first
pbandrb is offline   Reply With Quote
Old 09-10-2016, 07:30 PM   #18
kittlecat's Avatar
Did you try cleaning the area with an alcohol swab and then applying the Command strip? My walls are relatively smooth but I've got the Command strips stuck to wallpaper, glass, cabinets, pretty much everywhere in the camper except the doors, which are too rough in texture for the Command hooks.
Kittlecat
Old 09-13-2016, 04:55 PM   #19
yes we tried the swab and it held for a while and we even took pic down while traveling, maybe it is the southern NC heat
Old 09-13-2016, 05:00 PM   #20
asquared's Avatar
We use command strips to hold a wooden plaque, a wooden key holder and even the heavy duty stuff to hold the coat rack. No issues between 2 trailers in 4 yrs in NC heat and humidity and cold winters. Only issue was one that we placed up and then moved. Stuff works great!
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is online now   Reply With Quote
pictures
