I noticed after retracting the awing after our memorial day camping trip that the awing retracted back wards, meaning that the bottom (white side) rolled to the outside opposed to the roof (brown side). Any idea how to fix this? FR WW 261BHXL
TIA
Byron
If you hold the button it will just keep rolling back over itself - it does not stop automatically where it is supposed to
It should roll out with the roller UNDER the fabric but if you go too far it will lap itself and start rolling back towards the camper with the roller on TOP of the fabric - even if you are holding JUST the extend button
Just hit extend and keep holding it until it is rolling back from over the top like it should - it will go out and then you will see it correct itself and roll back like it should
When you fix it - only extend it until the flap hangs straight vertical down from the roller - do not go too far or water can pool more easily on top if you do not leave a small portion of the awning fabric over the top edge of the roller - it keeps more even tension to prevent pooling
once you get it out just watch the direction of roll when you start to bring it it. mine i can hear it click when flap is down and i have to let go of switch
Update: I was able to fix it today by doing as instructed above. I rolled it out and held the button down and it retracted it's self correctly. I will post a link to the manual. I did call lippit and they were very helpful .
