Old 07-14-2017, 09:40 AM   #1
Axle bearing grease
Hi all getting my TT ready for a cross country trip what grease would every one exponent for able bearings
micsol84 is offline   Reply With Quote
Old 07-14-2017, 10:00 AM   #2
Any wheel bearing grease should be good. But, just to be sure, contact the dealer, or a trailer repair/supply shop. I use "disc brake wheel bearing grease" in mine. It's a high temperature grease. Be sure to properly torque the bearings when you are reassembling so they aren't too tight, or too loose. There is a specific procedure for that.
otrtrucker is offline   Reply With Quote
Old 07-14-2017, 10:34 AM   #3
Ok thanks
Old 07-14-2017, 11:47 AM   #4
Don't just pump the grease in - pull the wheels, clean the bearings, and apply new grease by hand.
Watch some youtube videos if you aren't sure... its a pretty easy procedure.
Use lots of rags to clean all the old grease out.
mkosu04 is offline   Reply With Quote
axle
