Old 01-05-2015, 06:05 PM   #11
Crusadernoob's Avatar
The best way to measure is spindle to spindle, it's the only accurate way. Some like to measure wheel to wheel, just make sure one is not bent.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is online now   Reply With Quote
Old 01-05-2015, 06:36 PM   #12
trbomax's Avatar
Spindle to spindle is a slightly more accurate way to do it. When I had my fab shop we buit quite a few special purpose trailers from scratch, with up to 4 - 7000# axles. When the frame is being laid out and tacked up,it is upside down on a frame jig. This makes it easy to square up the spindle ends and take measurements. After it built and right side up with a body and hubs on it,this is next to impossible. All frame shops that I ever saw use spring centerbolts as a reference while straightening and adjusting any vehicle /trailer frames,unless there are laser measureing points on the unit being worked on.But,to each his own!
edit) It is assumed that when a frame is being measured, by any means,it is completely level in both planes,with the load removed from the springs. On a tt or 5er this could be done with 5 bottle jacks and preferably a laser level.
trbomax is offline   Reply With Quote
Old 01-05-2015, 06:52 PM   #13
frame shop calls "trianglelateing"
I think you mean "triangulating." Comes from "triangulate" meaning to "form into a triangle or triangles" as in "the brackets triangulate the frame"
2011 Traverse LT, 3.6L, FWD
Old 01-05-2015, 07:04 PM   #14
trbomax's Avatar
Spelling and punctuation are NOT my good points!Dont even ask how I got thru eng school!
Old 01-05-2015, 07:18 PM   #15
Thekipkers's Avatar
Good deal thanks for the info.
Thekipkers is offline   Reply With Quote
Old 01-05-2015, 09:41 PM   #16
4 years ago I couldn't even spell ennngineeer. Now I are one!
Old 01-05-2015, 09:52 PM   #17
trbomax's Avatar
More like 50 yrs in my case!
Old 01-06-2015, 08:31 AM   #18
Infractee
Originally Posted by Thekipkers View Post
Odd question, but I have noticed when placing my xchocks on my 262bhxl that the distance between tires is on each side is different.
The TT seems to tow fine, just curious if this is something that will create issues down the road etc
Is your unit springs or torsion axle?
Our last camper had torsion axles and both tires were spaced evenly (using X-Chocks you can tell right away) On our new Wildwood Heritage Glen I find that the tires on left side are closer together than on the right side, so now I keep the X-Chocks on the same side so that I do not need to open or close it before installing. I also noticed that my rear axle is slightly askew as the left rear tire "sticks out" in relation to left front tire by about 3/4" ~ 1" and correspondingly the right rear tire is inboard of the right front tire by about the same. (tho it could be the front axle that is off but when looking at it the rear axle seems to be off) When I had it in for insurance and warranty work this past summer I explained both problems and had them do a check on it, they came back with perfectly normal. Tires are not wearing odd at all, trailer tows straight as an arrow with no weird habits so I am rolling with it.. (pun intended)
RhoZeta is offline   Reply With Quote
axle
