Old 03-11-2012, 10:55 AM   #11
2012 Wildwood Xlite model 24QB with back pack edition. Tag on rear drop down carrier says 200 lbs. New trailer and tag is already faded.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 03-11-2012, 10:58 AM   #12
Tag from back pack.
FROG Member
Old 03-11-2012, 11:49 AM   #13
chuck9997's Avatar
thanks.. that's what I am looking for. Mine has the same tag.. but it was more faded. I rubbed to get some dirt off.. and the remaining faded print came off before I read it.
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 03-11-2012, 12:57 PM   #14
rockin'ray's Avatar
I think they use the same BackPack on all models. My 17EXL also says 200lb on the label.
rockin'ray is offline   Reply With Quote
Old 03-14-2012, 01:45 PM   #15
Wt limit
Would have to check to be sure but think the rating on ours was 200lbs.
I know it will hold more than that because I have stood on it several times. I would guess the reason for what seems like a low weight rating is that adding 500 or so pounds to the rear of your travel trailer while towing it is probably not a good idea.
wvcampincpl is offline   Reply With Quote
Old 03-14-2012, 02:52 PM   #16
Director, FROG
F.R.O.G.'s Avatar
Keep in mind, too, that you weren't jumping up and down on it and adding more stress the way a load will on some roads.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 05-26-2012, 11:55 AM   #17
We have the Backpack on our 2012 26bhxlt and the sticker says it's rated for 250lbs. It looks exactly the same as the OP's. My guess is that the different weight rating is less about how much it can hold and more about the shorter the trailer, the more difficult increased weight on the backpack will make handling.
On a related note, I'm thinking of building a box and putting our 150lb generator on the backpack. Pros and Cons for this? I think it should weigh under 200lb full of gas.
Spidey is offline   Reply With Quote
Old 06-01-2012, 01:17 PM   #18
I have considered hauling our generator on the backpack but to this point we have had room in our TV and I figure with the rack down that just adds another couple of feet in length I have to worry about. I know there are issues about too much weight to the rear or front and I am by no means an expert but I like the idea of hauling the generator on the backpack.
David & Sherry
2012 Wildwood 28BHXL
2013 GMC Sierra SLE
Old 06-03-2012, 10:43 PM   #19
Correction: I just double checked and the backpack is only rated at 200 lbs. Sorry for any confusion - there was a nick on the label that made it difficult to read at first glance. I'm still contemplating mounting a generator on the back but be within the 200lb rating. Surely Forest River factored this in when they created the Backpack Edition. I may call a factory rep. just to make sure. Being that the freshwater tank and pass through storage is at the very front, I think this will go a long way to mitigate tongue weight being less with extra weight on the back.
Old 07-17-2012, 09:16 AM   #20
I believe it is around 350 lbs on my 2013. can't confirm at the moment since my unit is at the dealer having the brakes checked. I will check when i get it back but that 350 includes the weight of the spare tire. yours problably doesn't have the spare attached at the rack.
tkerins is offline   Reply With Quote
