Old 04-12-2018, 10:54 AM   #1
Battery charge rate on shore power ?
Hi, my converter says it's the 55amp model, does anyone happen to know at what amp rate it will charge the batteries at when I am plugged in ?
iceclimber is offline   Reply With Quote
Old 04-12-2018, 12:25 PM   #2
Maybe 20 amps when the bank is below 80%, after 80% maybe 7 amps or less. Of course this depends on if you have a converter that will stay in boost mode (PD converters are pretty good at it) They say 4 hours...and there it is!
Here is a real test starting from 66% SOC and running up to 88%. This was a PD9270 that was manually forced into a 4 hour boost cycle. 4 12 volt batteries in house bank. I have a very long feed from the converter to the bank and it is only #8 or #6, so you can see I would do a lot better if I upped it to maybe #4 or larger. Costs me a more than a volt at 35 amps.
Name:	PD9270 Boondocking Cycle.png
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 04-12-2018, 12:57 PM   #3
Interesting, so it's pretty capable. The reason I am asking is when I use my generator, does it make more sense to hook it directly to a battery charger or to the trailer. Thing is stand alone battery chargers only push so much unless you go to like a 30/40 amp Xantrex and they ain't cheap,
I'll hook to the trailer I guess.
Old 04-12-2018, 01:00 PM   #4
The best thing to do is relocate the converter close to the batteries so you have low voltage drop.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 04-12-2018, 01:20 PM   #5
Flybob's Avatar
Some of the generators do not recommend using the 12V output to charge the battery. In general you are best off to connect the RV power cord to the generator and let the converter charge the battery.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-12-2018, 10:25 PM   #6
Not sure what you are referring to. I've never seen a generator with a 12v output. I was talking about using a battery charger plugged into the generator.
Old 04-12-2018, 11:09 PM   #7
bikendan's Avatar
Most inverter generators have 12v charging cables but it's the slowest way to charge the battery.
Using jumper cables to the TV battery is faster.
Equalizer WDH
Old 04-13-2018, 09:33 AM   #8
So now you made me go look, and sure enough it has a 12v socket and a couple small bayonet plugs, so I learned something.
I'd never use those. Idea is to push maximum amps at my 230 Amp hour batteries and that's either a Xantrex or the trailer plug in, which is what I have traditionally used. At the end of the day my generator is 30 amps anyway.
Old 04-13-2018, 07:14 PM   #9
camaraderie's Avatar
Your generator is 30 AC amps..or roughly 300 DC amps!
Your converter is capable of putting out 55 DC amps into a battery bank with large wiring and close proximity.
If you have 230 amp hour batteries (2x6V??) you probably CANNOT push more into them than 46amps even with a 100amp charger...and that would only be for the first couple of hours in bulk mode before they settle into absorbtion and then float mode.
Wetcell Batteries can only take about 20% of their rating in charge current.
So..you have all the charging capability you need right on board. If you get a battery monitor (which you should have if you boondock ...see Victron or Trimetric)...or if you get a clamp on DC meter ...you will be able to read instantly what is getting to your batteries including most other stuff ...(when do I need to recharge, when can I stop charging, how much longer can I use this stuff before needing to recharge, what charge stage am I in, how many amps does my blender use etc.) NOTHING else will tell you this stuff about IN USE batteries.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 04-13-2018, 07:41 PM   #10
Old-School
I still have an old -50/0/+50 amp ammeter I used in a with only idiot lights back in the early 1960s. I've got heavier leads on it now, and can put it in series with a battery charger or converter and the batteries. It's a Stewart-Warner with a nice chrome bezel, white on black face.
I was just looking to see if these are still available--a really inexpensive way to see what's going on. I found this one.
Larry
Larry-NC is online now   Reply With Quote
battery, power
