Old 07-08-2016, 12:23 PM   #11
Flybob's Avatar
If you have a build sheet for the 5er it should list the converter. Odds are you have a WFCO . You may also be able to get model from the unit ( should be in the same area as the fuse/breaker panel.). Just to be sure check current model as some new WFCO are supposed to have 4 stage capability. The progressive site will provide direct replacements for the one you have. As you have 4 sixes, you might consider a slightly higher current model ( as long as it has the same dimensions.) Switch out is fairly simple if you can do basic electrical connections.
Avatar needed a change will go back later. Barn owl is one of our raptors as well.
Progressive site RV & Motorhome Power Supplies, Converters and Centers
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-04-2016, 10:26 PM   #12
I charge once a month, that was prior to my solar panel install.
mfMcFroggierPod is offline   Reply With Quote
charging, battery
