Old 04-03-2015, 03:17 PM   #1
Adony's Avatar
Bed Hold Up Struts...
The original struts that came with the trailer (3 years old) wont hold the bed platform up while accessing the storage area underneath. We have added a mattress topper but I don'y think that it added that much weight.. The struts are marked GSNI-5300-60 Gas Spring.. The are extremely small in diameter.. Can they be replaced with a strut that has more holding power if available or should I assume that they have failed and just replace them with like units?
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 04-03-2015, 03:24 PM   #2
geotex1's Avatar
Yes you can replace them. Struts come in the same length with different ratings. The one you have is a 20" rated at 60#. Try an 80# version - GSNI-2300-80.
SPD GSNI Gas Spring Listing
Gas Springs
geotex1 is offline   Reply With Quote
Old 04-09-2015, 09:39 PM   #3
Adony's Avatar
Gas Springs
The 80 lb struts work great.. and with regular shipping I received them overnight.. Thanks for the info... Ted
Ted
2010 T25KS Wildwood
2006 F-250 SD
Old 04-09-2015, 09:55 PM   #4
You could have also re-located the anchor/pivot points of the struts to manage the extra weight.
Old 04-10-2015, 07:00 AM   #5
cpaulsen's Avatar
Did this with mine....moved the mounting about 2 inches further and now you lift the bed with one hand.
cpaulsen is offline   Reply With Quote
Old 04-10-2015, 07:04 AM   #6
Can you show pictures to help others? Might save them some $ wasted on new struts.
bed
