Old 06-17-2018, 08:07 PM   #21
First year owning a TT 2007, I tried everything under the sun and one day I did Dawn dish soap and bucket of water. Streaks came off faster than any product I'd tried. been using it ever since.
TheWolfPaq82 is offline   Reply With Quote
Old 06-18-2018, 11:46 AM   #22
NH Horseman
I echo the "Awsome" SUGGESTION.
NHHorseman is offline   Reply With Quote
Old 06-18-2018, 09:57 PM   #23
Canadian Member
S100 Total Cycle Cleaner
2019 Rockwood Signature 8290BS
Old 06-24-2018, 07:50 PM   #24
phillip252's Avatar
Originally Posted by aceinspp View Post
Do you delute or mix with water ? It says its consitrated. Later RJD
You definitely want to reduce it down.
phillip252 is offline   Reply With Quote
Old 09-07-2018, 10:50 AM   #25
Leecountry's Avatar
LA totally Awesome cleaner will take the wax off the camper. I have used it on mine and works way too good. I think after many times using it I have now streaks that you canít seem to get rid of and now camper is dull. Just use the black streak remover from wallyworld and keep the roof clean and it will help with black streaks.
Leecountry is offline   Reply With Quote
Old 09-07-2018, 11:14 AM   #26
Awesome will streak the paint, remove any wax, damage decals, and can permanently spot your glass windows. Read the instructions on the bottle, it says to wear gloves. That should tell you itís too aggressive to use on your RV.
Decon Blue is offline   Reply With Quote
Old 09-08-2018, 10:21 PM   #27
Awesome is to be used diluted.
If you aren't doing that, it's no wonder you have issues.
Days Camped: '16=46 '17=30 '18=51 '19=18
Old 09-08-2018, 10:31 PM   #28
Then read your earlier post, you say you never had problem , then why you now saying to dilute it ??
Old 09-08-2018, 10:49 PM   #29
Lets go camping!
str8t six's Avatar
i just use black streak remover from camco. works pretty good.
2014 Rockwood Mini Lite 2504s
2016 Ram 3500
str8t six is offline   Reply With Quote
Old 09-09-2018, 04:57 PM   #30
I've never had a problem using it diluted or at full strength.
My comment was if YOU do, maybe you should dilute it. It's apparent our experiences using it are different. I'll continue to do what works for me and I suspect you will as well.
black
