Old 05-27-2013, 04:02 PM   #11
bikendan's Avatar
could someone have used disposable/baby wipes or feminine products? those will definitely cause problems.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-27-2013, 04:13 PM   #12
prof_fate's Avatar
angel soft TP is RV safe, availble everywhere and 'soft'.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 05-27-2013, 04:21 PM   #13
fonzie's Avatar
Get one of these and push water back into your tank removing clog. Then drain and repeat a few times.
Flush King - Valterra FK-01 - Sewer Flushing - Camping World
Fonzie
Old 05-27-2013, 04:45 PM   #14
Black Water Tank wont empty
Try puting a 10-20 lb bag of ice down toilet and drive around to agitate it, use alot of water and anenzime cleaner to loosen the muck....try again to empty and repeat a couple of times.
Cmcsykes is offline   Reply With Quote
Old 05-27-2013, 05:04 PM   #15
kaldridge2004's Avatar
I have also heard that you can add ice (I think someone used 2 5lb bags) to help loosen anything that is 'stuck' on the walls of the tank. Then drive around and dump once the ice melts. This will help clean out the tanks.
2012 Rockwood 2109S MiniLite
kaldridge2004 is offline   Reply With Quote
Old 05-27-2013, 05:30 PM   #16
crunchman12001's Avatar
Bottom line is you put too much regular house paper down there. Next time use septic safe RV paper or what others have suggested. (it dissolves)
Also, make sure to use the RV toilet packet/chemicals before filling/using the tank next time. Full bowl of water with every paper flush.
You basically have what they call the brown pyramid. The paper built up under the trap and the liquid ran out.
You need to get the paper out. Your most sanitary option is to flush it out as described.
Plan B would be to get some trash picker uppers and pull it up out of the trap through the toilet if there is no liquid.
All else fails. Go to RV supply, buy a thing of tissue dissolver, some RID-X and a magic wand. Make sure the tank is full of liquid and add the chemicals. Let it sit for a few days. Find a campground or a place to dump at. Rinse and repeat.
Good luck
2015 F-250 FX4
Old 05-27-2013, 05:47 PM   #17
cplsms9300's Avatar
Good news everyone.... The great flush out worked. We ran a hose into the toilet and down into the tank. After a few minutes.... A great big gush and were back in business!! We did our best to get as much stuff out and I filled the tank up and ran it and the water was running clear! Thanks for all the suggestions and tips. We will be much more dilligent in ensuring that we use the right paper, pretreat and after treat this tank cause this was a mess!! Thanks again and happy rv'ing to everyone!
cplsms9300 is offline   Reply With Quote
Old 05-27-2013, 05:52 PM   #18
Glad you got it. Enjoy the summer!
crunchman
2015 F-250 FX4
Old 05-27-2013, 06:42 PM   #19
bubbles's Avatar
Just something to add. I don't think it was mentioned but you should allow your black tank to accumulate a good amount of water before dumping. It's ok to dump after a short time if you add a lot of water before doing so. The more the better, I believe, is the credence.
Old 05-27-2013, 07:47 PM   #20
Denver, CO
garbonz's Avatar
Originally Posted by cplsms9300 View Post
Garbonz... What is an external flusher? We have been using regular household tp but wont be anymore!!! I think the valve itself is eorking ok cause we did get some stuff to come out at the dump station. We will try the hose diwn the toilet. When I do this should the valve be opened or closed? I just dont want an overflow in the floor!! You know what I am saying? We are novice rvers and havent been doing this long at akl. It is all a learning process for sure! Thanks for everyones help!
Message #5 has the link, that device may unclog it also. And I like the drive around and try again, may be a cheap fix.
2017 Fuse 23T
