Old 05-27-2017, 08:37 PM   #1
Blown fuses
Any thought on why fuse for cook top range hood and lights in master bedroom of a brand new 2017 Wildwood kqbts keeps blowing? Any help would be appreciated. Thanks.
Picea is offline   Reply With Quote
Old 05-27-2017, 11:38 PM   #2
SeaDog's Avatar
If the fuse is blowing something is overloading it, try eliminating one thing at a time until it does't blow and you have found your problem
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-28-2017, 10:21 AM   #3
Thanks for the response. I'm checking everything possible. Was hoping to save some time. Thanks again.
Old 05-28-2017, 10:43 AM   #4
PPST Wannabe
kenandterry's Avatar
Cook top range hood....AC or DC powered?
Lights in bedroom....AC or DC powered?
AC stuff would be on a breaker.
DC stuff would be like an automobile fuse.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 05-29-2017, 07:21 AM   #5
DC powered. I just cannot seem to find the shirt that keeps causing the fuse to blow.
Old 05-29-2017, 07:29 AM   #6
Mr. Dan's Avatar
I'm guessing you'll find a wire pinched under a wall!!! or in a cabinet. I'd look under the unit (maybe even drop the bottom enclosure {if it has one} on the cook top side) to see if a smashed/chewed/squished wire can be seen.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 12
Old 05-29-2017, 09:17 AM   #7
Thanks. Started disassembling yesterday but have not finished yet.
Old 05-29-2017, 09:30 AM   #8
"Brand new 2017" and you are "disassembling"? It would be sitting back on the dealer's doorstep if it were mine if it were under warranty.
madmaxmutt is offline   Reply With Quote
Old 06-07-2017, 04:30 PM   #9
mblee21's Avatar
Is your cooktop part of a slide out? I had a similar issue with the lights. Every time I pulled my slide in it would blow a fuse. Turns out a wire under the slide out was bare and coming in contact with the metal and blowing a fuse.
mblee21 is offline   Reply With Quote
breaker
