My breaker panel on a 2018 BHXL is not labeled. Does anyone know what these breakers control? Would you have any photos of how yours is labeled so I might know where to start? I’ve written to Wildwood with no response.
Thanks in advance
DO NOT USE A PICTURE TO LABLE YOURS! Here is a list of possibilities you may have. It's not hard to figure it out. The main will be the 30. It has to be on for everything else to work. The A/C will be the 20. Turn it on. Turn the rest of what you have off then turn on one at a time until you find out what each is. It's not rocket science. If you have a an electric/gas WH that will be one. Conv. means convenience outlets. (plugs) usually called general circuits. Use a lamp. All outlets but the GFI's. GFI means Ground-fault Interrupter. It covers all outlets that are near water. Bathrooms and kitchen counters. Use a lamp. Be sure the GFI outlet is reset. One will be the fridge. Open the door. One will be the microwave. Turn it on. I think you have the idea.
Did exactly that. Found that 2 were labeled incorrectly
