Old 03-08-2018, 09:23 PM   #1
Breaker panel 261BHXL
My breaker panel on a 2018 BHXL is not labeled. Does anyone know what these breakers control? Would you have any photos of how yours is labeled so I might know where to start? Iíve written to Wildwood with no response.
Thanks in advance
jljj is offline   Reply With Quote
Old 03-08-2018, 09:27 PM   #2
bikendan's Avatar
You should be contacting your dealer first.
Equalizer WDH
Old 03-08-2018, 09:30 PM   #3
PoPo Cliff's Avatar
This is from my 2017 Wildwood 261bhxl. Hope it helps.
ID:	164632Click image for larger version
2017 Flagstaff 26RLWS
PoPo Cliff is offline   Reply With Quote
Old 03-08-2018, 09:37 PM   #4
Attachment 164632Attachment 164633
Itíll definitely be a place to start!!
Thanks!
Old 03-08-2018, 09:38 PM   #5
They were useless
Old 03-13-2018, 11:55 PM   #6
My panel had two breakers labeled backwards. Make sure you double check everything.
2017 Wildwood Xlite 273 QBXL
nate_ is offline   Reply With Quote
Old 03-14-2018, 01:16 AM   #7
cavie's Avatar
Thanks in advance
DO NOT USE A PICTURE TO LABLE YOURS! Here is a list of possibilities you may have. It's not hard to figure it out. The main will be the 30. It has to be on for everything else to work. The A/C will be the 20. Turn it on. Turn the rest of what you have off then turn on one at a time until you find out what each is. It's not rocket science. If you have a an electric/gas WH that will be one. Conv. means convenience outlets. (plugs) usually called general circuits. Use a lamp. All outlets but the GFI's. GFI means Ground-fault Interrupter. It covers all outlets that are near water. Bathrooms and kitchen counters. Use a lamp. Be sure the GFI outlet is reset. One will be the fridge. Open the door. One will be the microwave. Turn it on. I think you have the idea.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-14-2018, 01:37 AM   #8
wmtire's Avatar
Conv is usually just shorthand for the converter.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 03-14-2018, 08:07 AM   #9
cavie's Avatar
Originally Posted by wmtire;1754714[COLOR="Red"
]Conv is usually just shorthand for the converter.[/COLOR]
My bad it was late I did it again I fixed it Well I tried to fix it.
Old 03-14-2018, 09:11 PM   #10
Mine too.
breaker
