Old 08-19-2018, 09:50 PM   #1
Bunk Max Weight
Hi,
I just bought the 2018 WILDWOOD T27TDSS. Can someone tell me what the recommended max weight in the bunks is?
ArleneH is offline   Reply With Quote
Old 08-20-2018, 06:10 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. You might try using the search function at the upper right of the page there are tons of articles talking about this subject.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 08-20-2018, 09:52 AM   #3
I tried the search before I posted my question. I didn’t find an answer then and I didn’t find one now. Thanks for your help though.
Old 08-20-2018, 09:56 AM   #4
ArleneH, most max bunk weights are posted in/around the bunk area. Lift up the mattress, look on the underside of the bunk and in/around the beds. That being said, it may not be there and I would assume it is less than 150 lbs unless I found it posted.
We have had and still have at least one bunk in our RVs, one had a posted 200 lb weight limit, another had a 250 lb limit and another had a 150 lb weight limit.
merrykalia is offline   Reply With Quote
Old 08-20-2018, 10:03 AM   #5
Thanks merrykalia, I have checked the bunk area and all the documents I received with the unit and found nothing. I will assume it is 150 lbs. ��
Old 08-20-2018, 05:39 PM   #6
SeaDog's Avatar
I just did the search and found that the factory states 250 lb I did not look this up myself found it in the posts about bunkbed max weight. Not sure what search criteria you were using.
Retired Navy
Old 08-20-2018, 08:02 PM   #7
Thank you
Old 08-22-2018, 08:05 AM   #8
Misfit Adventures
Misfit011's Avatar
250 lbs on bunks
Misfit011 is offline   Reply With Quote
Old 08-22-2018, 10:04 AM   #9
Thank you
Old 08-22-2018, 02:18 PM   #10
In my Wildwood bunk room, the driverís side top bunk has a sticker that indicates 150 lb limit. Itís flimsy, I believe it. It tilts up out of the way and we donít use it. The passenger side is more substantial and is rated for 250.
EricEdwards is offline   Reply With Quote
bunk, weight
