Old 11-25-2017, 08:24 PM   #1
Bene Gesserit Rule
Murbella7's Avatar
Cable Management Devices Needed
The cable management strips under the slide-outs of my 28RLT 5th Wheel have broken at the end support points. Once due to an exploding tyre ripping all the cabling out, the others just due to bumpy roads.
I need suggestions for replacement, either the same kind or an alternative.
I have thought about using flexible corrugated hose but there is nothing under the van to use to support them away from the ends, at least not without drilling holes (and who knows what is on the other side) or making additional (and possibly welding) new brackets.
The original flat strips work well, they support the cables without drooping, whereas hose will droop without extra supports.
Murbella7 is offline   Reply With Quote
Old 11-26-2017, 08:12 PM   #2
2007 WildCat 32QBBS
05CrewDually's Avatar
Use a door hinge from the hardware store and reattach the broken end. I'll try to find a picture of what I mean.
05CrewDually is offline   Reply With Quote
Old 11-26-2017, 08:17 PM   #3
2007 WildCat 32QBBS
Here's a link to the solution.
Slidr Out Flex Guard
Old 11-26-2017, 10:04 PM   #4
Blender's Avatar
Attachment 157254
That痴 genius I like this idea, I知 sure I値l need it one day!!
Blender is offline   Reply With Quote
Old 11-27-2017, 02:00 AM   #5
Bene Gesserit Rule
Murbella7's Avatar
To misquote a quote... That's genius I like this idea. I'm sure I'll use it one day, actually pretty soon.
Old 11-27-2017, 08:39 AM   #6
mine broke also. look online for lippert slide out cable supports. I was able to get a replacement for about $25. there are many vendors that supply these. I installed it and it is working just fine. be careful as they come in different widths. if you go this way make sure you get the proper size. it was not hard to install. the hinge idea looks good also. just a matter of how you want to do the repair.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 11-27-2017, 03:13 PM   #7
MCTroy
Attachment 157254
Brilliant! Much better than my bungee!
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
MCTroy is offline   Reply With Quote
Old 11-28-2017, 07:50 AM   #8
Attachment 157254
I installed a hinge, but it broke again. I emailed FR and they replaced it under warranty. I installed the new one with a hinge and it is still working.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
cable
