03-27-2018, 02:34 PM
Can I hang a generator under our 24ft?
We have a Wildwood 24ft trailer.
Has anyone ever seen a generator hung under it that was large enough to run the air conditioning? I am not a fan of having to carry around a portable generator every place we go.
Thanks!
03-27-2018, 02:38 PM
You are not clear, but is appears that you are looking to travel with the generator under the TT. I doubt that you will have sufficient clearance under a TT to mount a generator. In addition, I would not want a portable generator running under my TT. I would not do it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
03-27-2018, 02:50 PM
I guess every place you go you should then have a pedestal...
Some owners have had a carry-all of some type welded to the frame/back bumper and put their inverter/generator there.
2014 Shamrock 183
03-27-2018, 03:01 PM
Sorry that I wasn't very clear. I would like to hang a non portable type generator under my TT. Maybe something made by Onan. It seems like there is enough space and ground clearance?
03-27-2018, 03:19 PM
I dont of any standard TT that this would be possible.
03-27-2018, 03:24 PM
Most TTs have boxes installed into the front storage and this is where you would mount the gen. If it isnt already installed from what I hear it is not an easy task for a DIY job (no experience myself but looking at TT where it is already there I wouldnt want to tackle it) You will need more than the genset, fuel lines, tanks, fill port, etc....
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
03-27-2018, 03:47 PM
Georgia Rally Coordinator
I had one hung under the rear of my 5er it was an onan and installed by the dealer. It was propane. My 5er had large 16 inch tires and was pretty far off the ground. Never had any issues with clearance and it looked like it was installed by the factory. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
03-28-2018, 12:30 PM
Two concerns
Two concerns - Heat? Could it make the trailer hot? Maybe cause a fire?
- Fumes? Exhaust stink up the interior? Carbon monoxide give you headaches? Or worse?
Larry
03-28-2018, 01:54 PM
I have a 250# listed rack on the rear of my 5er. I'm going to have a box made and welded to it for the genny, vents and all. Similar to a truck tool box. Would be interested in a pic of what you did though...
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
03-28-2018, 03:57 PM
You could probably do it, but, I would want a super exhaust system made up for it. If you run it with the stock little tailpipe the exhaust will find a way to come inside your camper and kill you. I have a 4,000 kw Generac made for a motor home that is very compact, but, you would still need around 18 inches for it and then maybe another foot to the ground to be safe. If you decide to do it, I will give you a deal on my Generac, brand new in the box, never been run, $500
Retired Auto body teacher
2021 Arctic Wolf 3550 Suite
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
03-28-2018, 05:12 PM
CW and other sell a genatator rack that mounts above the LP tanks.
03-28-2018, 05:18 PM
There is a Fiver owner on Vancouver island that had a bumper extension fabricated for his Rock-wood and has a Portable Yamaha inside. I can not remember his forum name. It was well done and looked profesional!
03-28-2018, 05:28 PM
OP has a 5-er. The storage rack you mention only works on "Bumper pulls".
Downside to mounting under or in compartments on any TT is that often the only available space is next to the sleeping area. Not where I'd want a generator located if I planned on napping on a hot afternoon.
03-28-2018, 05:48 PM
Bene Gesserit Rule
Not that I need to do it because my 3kw generator is bolted to my truck bed, but I am intrigued. These things are not light weights. What does that extra weight on the farthest point from the hitch do to the towing configuration? Does pitch the truck nose down further, or do you compensate somehow?
A gene designed to run under cover/in a locker would be nice, but hanging a regular unit under a TT, not my idea of a good thing.
03-28-2018, 05:56 PM
Mike, the OP has a TT, not a 5th wheel.
I think many are assuming it's a 5th wheel.
That's why I said what I said in my post.
03-28-2018, 05:59 PM
My 3500W generator/inverter weighs just over 100# filled with fuel. If I mounted it on my rear bumper it would probably reduce my tongue weight by maybe 30# - 40# due to the positioning of the axles. If I was that fussy about my tongue weight I could compensate by just putting an extra 8-10 gallons of water in my tank.
A larger weight shift occurs when one uses up the water in their fresh water tank Usually in front of the axles, and is now hauling much of that water in the holding tanks, often mounted behind the axles. A 40 gallon tank represents almost 350# or over 3 times what a portable generator weighs, as a rule.
03-28-2018, 06:42 PM
Not a problem for me. Like many models the FW tank is at the absolute rear of the 5er. I carry 60 gallon at all times.
03-28-2018, 06:48 PM
Sorry to say this conversion was done in 1999, camper long gone and no digital pics available. The camper was a Golden Falcon tho. Later RJD
Days camped 2019 62
03-28-2018, 07:05 PM
Well, the name Golden Falcon brings back memories. We had one about 10 years earlier than '99.
03-28-2018, 09:03 PM
https://www.amazon.com/dp/B01FAWMMEY...a-274789969898
I own this unit and it will run the A/C but barely. It's the start up that really tests a generator. Far as mounting it on my trailer, I thought about a bumper rack and I never got around to it. It's light enough to pick up...and set it farther away from your camper. I imagine if you have a genny hanging on a 24 footer you will really hear/feel it.
http://www.campingworld.com/trailer-...SABEgJRB_D_BwE
Here is the genny rack. I have to say, that looks....well not like something I would use.
