Old 03-27-2018, 02:34 PM   #1
Can I hang a generator under our 24ft?
We have a Wildwood 24ft trailer.
Has anyone ever seen a generator hung under it that was large enough to run the air conditioning? I am not a fan of having to carry around a portable generator every place we go.
Thanks!
speedfast is offline   Reply With Quote
Old 03-27-2018, 02:38 PM   #2
Flybob's Avatar
You are not clear, but is appears that you are looking to travel with the generator under the TT. I doubt that you will have sufficient clearance under a TT to mount a generator. In addition, I would not want a portable generator running under my TT. I would not do it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-27-2018, 02:50 PM   #3
rsdata's Avatar
I guess every place you go you should then have a pedestal...
Some owners have had a carry-all of some type welded to the frame/back bumper and put their inverter/generator there.
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
rsdata is online now   Reply With Quote
Old 03-27-2018, 03:01 PM   #4
Sorry that I wasn't very clear. I would like to hang a non portable type generator under my TT. Maybe something made by Onan. It seems like there is enough space and ground clearance?
Old 03-27-2018, 03:19 PM   #5
bikendan's Avatar
I dont of any standard TT that this would be possible.
Equalizer WDH
Old 03-27-2018, 03:24 PM   #6
Most TTs have boxes installed into the front storage and this is where you would mount the gen. If it isnt already installed from what I hear it is not an easy task for a DIY job (no experience myself but looking at TT where it is already there I wouldnt want to tackle it) You will need more than the genset, fuel lines, tanks, fill port, etc....
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 03-27-2018, 03:47 PM   #7
Georgia Rally Coordinator
aceinspp's Avatar
I had one hung under the rear of my 5er it was an onan and installed by the dealer. It was propane. My 5er had large 16 inch tires and was pretty far off the ground. Never had any issues with clearance and it looked like it was installed by the factory. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 30
Old 03-28-2018, 12:30 PM   #8
Two concerns
Two concerns
  1. Heat? Could it make the trailer hot? Maybe cause a fire?
  2. Fumes? Exhaust stink up the interior? Carbon monoxide give you headaches? Or worse?
Larry
Larry-NC is online now   Reply With Quote
Old 03-28-2018, 01:54 PM   #9
CaptnJohn's Avatar
I have a 250# listed rack on the rear of my 5er. I'm going to have a box made and welded to it for the genny, vents and all. Similar to a truck tool box. Would be interested in a pic of what you did though...
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 03-28-2018, 03:57 PM   #10
old40ford's Avatar
You could probably do it, but, I would want a super exhaust system made up for it. If you run it with the stock little tailpipe the exhaust will find a way to come inside your camper and kill you. I have a 4,000 kw Generac made for a motor home that is very compact, but, you would still need around 18 inches for it and then maybe another foot to the ground to be safe. If you decide to do it, I will give you a deal on my Generac, brand new in the box, never been run, $500
Retired Auto body teacher/Retired RV Dealer GM
2017 Puma 255RKS
2019 F-250 Lariat Super Crew 6.2
No Kids
No Pets
But lots of Fun traveling with my wife
old40ford is offline   Reply With Quote
generator
