Old 02-28-2008, 09:15 PM   #1
cap of tanks
I just purchased a 2000 27rkss 5th wheel and wanted to know if anyone know the cap of the tanks. It has one for the galley, one for shower & lav, and black water.
lemitch is offline   Reply With Quote
Old 02-28-2008, 09:19 PM   #2
If you don't get an answer, you can take a 5 gallon bucket and fill it with water. Pour it down the drain for each tank. Count the number of 5 gallon buckets it takes to fill each tank and you will have your capacity.
Hokiehall is offline   Reply With Quote
Old 02-29-2008, 05:08 AM   #3
HookupAndGo's Avatar
Look in the cabinets over the sink area. It will have at a minimum the weight capacities. They usually/sometimes have the weight of the heavier items, such as tanks. If it does, then you can just divide the distinct "tank" weights by the weight of water....it will give you a rough guestimate.
HookupAndGo is offline   Reply With Quote
wildwood
