Old 09-04-2019, 07:09 AM   #1
Mike223's Avatar
Change out thermostat
The used Forest River Wildwood 230BHXL I just bought has a ceiling a/c (not ducted) and has a Suburban thermostat. Any suggestions as to what digital thermostat I should get to swap it out?
Thanks, Mike
Mike223 is offline   Reply With Quote
Old 09-04-2019, 07:22 AM   #2
So the thermostat is just for the furnace? If so then there are many digital thermostats that will work.
Here's a non-programmable one Digital Heat Only Thermostat
Gotta go campin!
Old 09-04-2019, 12:15 PM   #3
Another option would be to get the model number from the existing thermostat then "google" "Replacement thermostat for model number XYZ-????"
This usually shows direct digital replacements.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
thermostat
