It is caused by the expansion and contraction of the thin wood (LUAN) under the vinyl covering that is applied to it. As the wood expands and shrinks, it wrinkles the covering. Usually happens near a place where the wall/ceiling sheet is trapped by another piece of wood or trim. In your case, the cabinet.
I have seen this in several units we've owned and even in a manufactured home we lived in. As your rig ages, you'll likely see a few other spots develop. I've even seen it in brand new units at some of the R/V shows.
Although moisture can cause a similar issue, this has nothing to do with condensation.
