Old 06-17-2017, 02:52 PM   #1
Constant Hot Water
I bought a TT recently after several rentals. We are pretty happy with it. While I can live with the 6 gallon water heater my wife and 3 daughters can not. As they are not bath house friendly I have purchased a Surburban IW60 to install. I did some searching and this was the unit with the least bad reviews. I plan on installing it next week. I do have plumbing/gas experience. Does anyone have any tips on an install ?
2017 Wildwood 30KQBSS
Gunnar72 is offline   Reply With Quote
Old 06-17-2017, 03:17 PM   #2
Ours came with the 10, previous tt had the 6. 10 works very well.
If you run the gas with the electric during the 1st shower it will lengthen
the second or more showers.
Don't forget to tun then gas off when done.
2015 Forest River Grey Wolf..Traded
2015 Forest River Cherokee 274RK
2001 2500hd...garaged
2015 Rubicon 2d and 2015 Jeep SRT
Simplewon is offline   Reply With Quote
Old 06-17-2017, 03:37 PM   #3
bikendan's Avatar
Also get a shower head with a turn off feature, like the Oxygenics Body Spa.
The ladies will still have to learn to conserve, if you don't have sewer hookups.
Equalizer WDH
Old 06-18-2017, 10:31 AM   #4
gpaw56's Avatar
We have the Oxygenics shower head and really like it. The way it works makes it feel like the water pressure is greater. Almost like a shower massage
gpaw56 is offline   Reply With Quote
Old 06-18-2017, 11:01 AM   #5
wmtire's Avatar
I don't have a tip on the install but possibly one afterwards. Since you are installing an on-demand type water heater and will have 4 other family members using it for showering purposes as per your OP above..... even though you will have all the hot water you need, it's still going into a drain and possibly the grey water tank that will fill up if not camping at sites with sewer hookups. You may still want to limit the time in the shower, even if hot water supply isn't the problem, the grey water can be if you fill up the holding tank. Just something to maybe consider.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 06-18-2017, 11:44 AM   #6
You are "Committed"to FHU Sites Only! Water management is a MUST,start NOW or your Camping Life is Not going to be Pleasant! Youroo!!
Old 06-18-2017, 08:44 PM   #7
We typically camp at full hookup sites. I would love to venture into some parks that I understand do not have the full hookups. I'm hoping that the heater will work if I choose to do so and we are using the "navy shower" method.
If we are at a full hookup site I understand it best to leave the gray water dump valve open.
Old 06-18-2017, 08:59 PM   #8
Did you have both the gas and electric turned on for the water heater? This will somewhat increase the time before you run out of hot water, and will also speed up the time it takes to recover.
A lot of folks have reported issues with instant hot water heaters. You may be swapping one problem for another. But good luck.
With you and 4 females in a trailer, I'd wager that the HWH is probably the LEAST of your worries; it's probably just the only one you can do anything about!
2011 Traverse LT, 3.6L, FWD
Old 06-19-2017, 11:29 PM   #9
Keep us posted on how it turns out. I know the limits of tank storage, but I'm usually at a CG with full hookups, the DW likes longer showers, and this has been a topic of conversation.
spydunks is offline   Reply With Quote
Old 07-10-2017, 07:33 PM   #10
Won't work
I have done my best to get this water heater to work. I am getting no hot water from this thing.
hot water, water
