Old 02-14-2019, 02:41 PM   #1
Correct tire size.
I just bought 2019 FR Wildwood 26DBLE Limited Edition TT. Yellow sticker on side of trailer reads tires are 225/75/15 but actual tires on trailer are 205/75/15. Should I call FR to check the size actually recommended or is it no big deal. Thanks.
horsrman is offline   Reply With Quote
Old 02-14-2019, 02:54 PM   #2
Yes you should dig into this. The 205 tire may or may not be of the correct weight rating.
Our Coachman was delivered with Alloy wheels that were one size larger in width than the sticker.
I would bet the dealer swapped wheels with another trailer.
MtBiker is offline   Reply With Quote
Old 02-14-2019, 03:14 PM   #3
Fulltime family RVer
I would expect it to match. If the tires are different from the factory, then a NHTSA complaint should be filed. And the factory/dealer should make it right.
If the tires are different because of the dealer, they should make it right.
In both cases, I'd want a logical explanation as to why it was different.
ependydad is online now   Reply With Quote
tire
