Old 08-20-2014, 06:56 PM   #11
jawga's Avatar
same here just spliced into the light in the bathroom, no other cutting is required since the hole is the same size
jawga is offline   Reply With Quote
Old 08-22-2014, 02:11 PM   #12
Golfnbike13's Avatar
Is this all I need? I just have a regular vent with no fan currently.
http://m.campingworld.com/shopping/i...-upgrade/59009
Golfnbike13 is offline   Reply With Quote
Old 08-22-2014, 02:13 PM   #13
bbrider's Avatar
Vortex II Vent Fan Upgrade - Heng's Industries 90046-CR - Vents - Camping World
Yep, that is what I bought for mine. You will need to tap into a nearby light for power.
If you don't know where you are going..... then any road will get you there.
2005 F250
2014 Wildwood Lite FS 185rb
bbrider is offline   Reply With Quote
Old 08-22-2014, 02:16 PM   #14
bbrider's Avatar
Cheaper on ebay where I got mine.
RV VORTEX II - 5 SPEED replacement roof vent fan upgrade 12 Volt 9” Blade
2005 F250
Old 08-22-2014, 02:18 PM   #15
Thanks, I'm picking this up today and planning to install this weekend. Where did you run the wires from the light? Maybe I'll see when I take down the light, but is there space to run them inside the roof or do they just go across the ceiling and in view?
Old 08-22-2014, 02:39 PM   #16
bbrider's Avatar
There is a gap between the roof and the ceiling. If the light is close you can probable just reach in and pull the wires over to tie into them. If not you may have to snake the wires over from the vent to the light with a clothes hanger or something.
2005 F250
Old 08-22-2014, 04:52 PM   #17
jawga's Avatar
also the single speed one is much cheaper, that is the one we have
Old 08-24-2014, 03:52 PM   #18
For some reason I can't get my fan to fit the opening. The plastic tabs on the side hit the metal frame of the vent cover before the crank spindle reaches into the gear drive. Did you have to trim anything or make modifications to fit?
Old 08-24-2014, 06:39 PM   #19
Scratch that, got it to fit. Should the Forward speeds take air out of camper and Reverse blow air down inside? To me that seems opposite but I matched the wires by color. Click image for larger version
Name:	ImageUploadedByForest River Forums1408923559.922366.jpg
Old 08-24-2014, 07:16 PM   #20
Brother Les's Avatar
Scratch that, got it to fit. Should the Forward speeds take air out of camper and Reverse blow air down inside? To me that seems opposite but I matched the wires by color. Attachment 61382
Your camper, make it go which ever way you want.
Brother Les
camper
