Old 02-28-2010, 07:18 PM   #1
wildwood's Avatar
delamination of wall paper
we have a wildwood 2008 29lebhbs. in several places around sink the wood finish paper has delaminated from wood, any others had this problam and if so what can be done. service center says real expensive to try to fix.
also just had to have pc board replaced on furnace for warranty repair, glad it had two year warranty
2008 Wildwood LE 29BHBS
wildwood is offline   Reply With Quote
Old 02-28-2010, 07:55 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Try a syringe with an adhesive. It will create a small hole but you should be able to get the wallpaper to reattach. If it's below the cabinets and above the counter-top you could try a wall panel splash guard similar to what NWJeeper install in the kitchen of his motorhome. I did the same as him so I could remove the mirrors FR had installed.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
wildwood
