Old 09-19-2016, 06:36 PM   #11
those bases are very flimsy, I tripped over DW's footstool and table broke my fall, i think ares was cracked before since wobbly and i made the comment to DW that screw heads popped through the holes here is a pic, how much are replacement
ID:	120707   Click image for larger version
pbandrb is offline   Reply With Quote
Old 09-19-2016, 07:41 PM   #12
crunchman12001's Avatar
Hi, The price is just as cheap as they are made. $7.91 here,
RV Pedestal Table Legs at PPL - PPL Motor Homes
Also look on Amazon.
2017 Salem Villa Estate 395RET-Coming soon
2015 F-250 FX4 SUPER DUTY 6.2L Gas 4WD SuperCab XL 3.73 rear / 158" WB / 8' bed. Factory anti-sway and brake controller
crunchman12001 is online now   Reply With Quote
Old 09-19-2016, 07:44 PM   #13
thanks for the link
Old 09-19-2016, 07:50 PM   #14
thanks for the link
You are welcome.
Make sure you use the exact same size screws to reinstall the new base. If the table is in a slide, you will go through the floor and damage your tile when you bring the slide in.
Old 09-20-2016, 12:14 PM   #15
You are welcome.
thanks for the tip as well, i did keep old screws, i thought about a washer seemed like head went through hole on some
Old 09-24-2016, 11:41 AM   #16
whoot dealer covered part under warranty
Old 09-24-2016, 05:58 PM   #17
Good to hear, thank you for the follow up.
