Old 09-18-2016, 07:51 AM   #1
Jonp154's Avatar
Dinette table
In my 2017 wildwood 230 I noticed my dinette table is wobbly. When I looked at the legs I noticed the front base is screwed down but the rear base has no screws and can be swung around. Is this normal? Or a factory goof?
Jonp154 is offline   Reply With Quote
Old 09-18-2016, 08:00 AM   #2
crunchman12001's Avatar
If you post a picture, we can tell you how to fix it.
2017 Salem Villa Estate 395RET-Coming soon
2015 F-250 FX4 SUPER DUTY 6.2L Gas 4WD SuperCab XL 3.73 rear / 158" WB / 8' bed. Factory anti-sway and brake controller
crunchman12001 is online now   Reply With Quote
Old 09-18-2016, 08:05 AM   #3
Jonp154's Avatar
WClick image for larger version
Name:	ImageUploadedByForest River Forums1474200303.763076.jpg
Old 09-18-2016, 08:06 AM   #4
Jonp154's Avatar
Name:	ImageUploadedByForest River Forums1474200377.087443.jpg
Old 09-18-2016, 08:07 AM   #5
Jonp154's Avatar
There are no screws in the tables rear leg base. Not sure if is a goof as the table wobbles
Old 09-18-2016, 08:11 AM   #6
Yes, there should be a screw in every hole. You have to be careful when you put the new screws in if the table is in a slide due to the thickness of the slide floor. Take a screw out of the good side and buy the exact same from the hardware store. If the new screws are to long, you could damage the floor when you bring the slide in. Easy fix. Also check those from time to time, they work themselves lose.
Old 09-18-2016, 08:12 AM   #7
Jonp154's Avatar
Thank you
Old 09-18-2016, 08:18 AM   #8
Originally Posted by Jonp154 View Post
Thank you
You're welcome.
Old 09-18-2016, 11:22 AM   #9
Phenom's Avatar
Had the same on my wildwood 28dbud. I had it in for other warranty work and although it seemed silly, I had just them throw some more screws in there. Must've been near quitting time on Friday when they did the table.
Sean
'16 28DBUD
'16 2500HD Dmax
Phenom is offline   Reply With Quote
Old 09-18-2016, 11:31 AM   #10
Agree 100%! Youroo!!
